I got a problem
Old Jan 7, 2004 | 02:50 PM
808b18c1boosted's Avatar
Default I got a problem
Im pretty shure i blew a ring land #4 cyl at the drags cause white smoke started coming out my breather and my exhaust.But now my breather spits oil and my car overheats cause i keep on loosing coolant. I did a comp test and that verified my ring land problem #1 128 #1 126 #3 125 #4 46 kinda bad. My leak down test showed 50% . could i have killed two birds with one stone ring land and blown headgasket. thanks
Old Jan 7, 2004 | 02:53 PM
Ri5e's Avatar
Default Re: I got a problem (808b18c1boosted)
Or maybe even cracked the sleeves
Old Jan 7, 2004 | 03:02 PM
Default Re: I got a problem (BG Boost)
i hope not. do you think i could have cracked the head to
Old Jan 7, 2004 | 03:05 PM
FULLTHROTTLE's Avatar
Probably cracked the sleeve or blew the headgasket.
Old Jan 7, 2004 | 03:07 PM
rjardy's Avatar
Default Re: I got a problem (FULLTHROTTLE)
only way to find out is to pull the head. I highly doubt you cracked a sleeve. Whats your setup to include power output?
Rob
Old Jan 7, 2004 | 03:13 PM
Default Re: I got a problem (rjardy)
If it was just the headgasket would it still blow smoke and oil out the breather
Old Jan 7, 2004 | 03:16 PM
99 civic
96 gsr motor ,drag 3 kit , skunk 2 mani
440 rc , v afc ,
Probably not. It would blow combustion gasses into the radiator or there could be coolant in the oil and oil in the coolant. Excessive blowby from the oil breather is most likely coming form a smoked ring or broken ringland.
o yea dynod in at 256whp and 191tq
Old Jan 7, 2004 | 03:18 PM
thats what i figured but my coolant is going somewhere fast and not on the ground. plus no coolant in oil but i got some small specs in coolant
Old Jan 7, 2004 | 03:22 PM
Odds are its a Head gasket. Before you tear it down though do a good compression and leak down test to find out which holes are giving you trouble. Also dont rule out the possibility of a broken ring to boot.
Old Jan 7, 2004 | 03:27 PM
i did the leak down test, cyl 1-3 are about 12% but # 4cyl is 50% leakage
garnet
Oct 6, 2007 02:02 PM
blumpfish
Jun 18, 2006 09:23 PM
311
Jul 13, 2004 11:54 AM
b18c5T
Jan 31, 2004 09:44 PM
TORQUE MONSTER
Apr 23, 2003 08:28 PM
