I broke all the top ringlands!
Old Oct 28, 2002 | 06:46 PM
filetofit
Guest
Posts: n/a
Default I broke all the top ringlands!
So even though I only had low compression on one cylinder I decided what the hell, rather than just replace one stock piston I'll upgrade to JEs. Took the stock LS pistons out,... every top ring land was broken and on one of the pistons the second ring land was broken as well. All were broken in about a 90 degree arc centered on the intake side.
Running the MAP hack with about 11 psi, 450cc injectors. 10 degrees retarded at the distributor apparently wasn't enough. Maybe it was that @#$%&* deltagate.
PLugs looked fine by the way and I couldn't hear any detonation but then again with a 3" thermal exhaust at WOT you can't hear much else anyway.
Old Oct 28, 2002 | 07:20 PM
legendboy's Avatar
Default Re: I broke all the top ringlands! (filetofit)
damn! what engine??? I'm running a similar setup on my LS. SAFC & 440's, BTM
@ .75 and stock distributer timing. I hope that doesn't happen to me!
Old Oct 28, 2002 | 07:57 PM
B18EG6's Avatar
ignorance taking hold here...wat are ringlands?
filetofit
Guest
Posts: n/a
Default Re: I broke all the top ringlands! (legendboy)
b18a i.e. pr4 pistons
Old Oct 28, 2002 | 09:42 PM
ion_four's Avatar
hey man, do you mean your timing was 10º BTDC, or 16-10º = 6º BTDC?
I got my BTM installed FINALLY on sunday...I blew the damn coil the fist time. Hopefully my motor still loves me...the vaccum seems a bit low (18 in. as opposed to 22in.)...
Old Oct 28, 2002 | 09:53 PM
texan's Avatar
Default Re: I broke all the top ringlands! (B18EG6)
See those grooves where the rings are installed? The sections of metal just underneath each groove are called ring lands, they're what support the rings.
Old Oct 28, 2002 | 09:56 PM
filetofit
Guest
Posts: n/a
Default Re: I broke all the top ringlands! (ion_four)
10 degrees retarded i.e. 6 degrees BTDC, not 10 degrees BTDC. Basically I turned the distributor clockwise as much as I could. I must have had some detonation and just couldn't hear it.
Old Oct 29, 2002 | 12:04 AM
VaporTrail's Avatar
New User
did you tune the a/f at all with a wideband?
Old Oct 29, 2002 | 04:31 AM
RGAZ's Avatar
New User
File, You need boost depandant retard, not just base timing at 11 psi, you are nuts.
Some detonation? You had alot of detonation.
You could have run fine at 7psi or so, too bad you went for 11.
Time to rebuild bigger and better.
Randy
Old Oct 29, 2002 | 05:38 AM
Kevin's Avatar
Default Re: I broke all the top ringlands! (RGAZ)
Ive heard this too many times, we did the same thing on our Civic, the cause was a boost spike.
EFgsr Turbo
Engine Management and Tuning
16
Apr 16, 2015 08:28 PM
Aesthetic Gains
Mar 14, 2012 05:45 AM
ITR.#1446
Sep 12, 2008 11:30 PM
mekanism
Oct 11, 2005 04:51 PM
LB CRX
Jul 15, 2002 02:45 PM
