hx35 turbo
Old Jan 9, 2014 | 12:40 PM
t70accord's Avatar
Default hx35 turbo
contemplating on running a hx35 turbo but im not sure what a hx35 is equivalent to and not really sure on the max hp its rated for. can it get some help please
Old Jan 9, 2014 | 12:47 PM
Sebba's Avatar
Default Re: hx35 turbo
So what, you picked it because it has a pretty name? Turbos don't have 'max hp ratings', they have flow ratings, typically in CFM (cubic feet per minute).
Why don't you start by googling what a compressor map is, how to read one, and take a gander at the compressor map for the particular HX35 you're looking at? Also, take a moment to observe all the different variations of HX35 available.
Then, you'll be able to answer all of those questions yourself, and make the right choice for your setup.
Old Jan 9, 2014 | 12:53 PM
hardcore97's Avatar
Check out the holset users unite thread. Tons of info there. I have an hx35 on my lsvtec for the time being. Got a lot of info from that thread
Old Jan 9, 2014 | 01:27 PM
t70accord's Avatar
No i picked it because I know they are reliable turbos and I figured I can make good power with them. And also I can get really good deals on them. I know there are different variations of hx35s I'm just looking for info on what size or variation of housings would give me the most hp. And I'm not to keen on reading compressor maps.
Old Jan 10, 2014 | 06:25 AM
TheShodan's Avatar
Moderator
Check the Holset User's Unite thread and find out which particular ones they're using to guide you. Otherwise, check the DSMtuners.com forum, as they are big on Holset and know the subtle differences in their designs, although they do tend to run them at better pressures than the average Honda user.
Old Jan 10, 2014 | 08:07 AM
Sebba's Avatar
So you're too lazy to educate yourself on the subject, and want everyone to spoon feed you information like a third grader.
Got it.
Old Jan 10, 2014 | 08:58 AM
BLU CIVIC's Avatar
Track Advocate
http://www.turbobygarrett.com/turbob...ompressor_maps
Old Jan 10, 2014 | 09:08 AM
wantboost's Avatar
Who is Mr Robot?
if you can't read a compressor map then you cannot effectively size a turbo properly for your application
learn to do that first before selecting any turbo... and read the Holset thread. all the info you could ever need and we could ever tell you has already been posted in there
Old Jan 11, 2014 | 08:11 PM
B and B's Avatar
Loved
Community Favorite
Old Jan 11, 2014 | 10:00 PM
a1320honda's Avatar
10.9@129 on 16lbs
Old Jan 17, 2014 | 12:05 AM
extremeracer's Avatar
Whilst there is a ton of variation in Holset's line-up withing one range (like HX35), the most commonly found HX35's are as follows:
8 blade 56mm compressor wheel - +-52 lb/min
7 blade 54mm compressor wheel - +- 60 lb/min
Equivalent to a GT3076R with a bit more flow (7 blade version)
Make sure you have a 12cm2 turbine housing
Twin scroll, robust turbo with good spool and a solid 500whp capability
Old Jan 17, 2014 | 03:44 AM
TheShodan's Avatar
Moderator
Divided housing robust turbo with good spool and a solid 500whp capability
fixed that for you..
Geis
Dec 18, 2014 08:04 AM
machine4321
Apr 14, 2010 04:02 AM
ej1252
Nov 11, 2007 08:03 PM
Sonny
Jun 12, 2003 12:08 AM
B18EG6
Dec 11, 2002 03:20 PM
