Hump Hose Necessary?
Old May 22, 2004 | 04:57 PM
TurblowR's Avatar
Default Hump Hose Necessary?
Are hump hoses necessary? i have a drag gen III kit, will the supplied silicon hoses with t-clamps/bolts be okay? i really dont want that stuff to be blowing off. Experts please advise. Thank you.
Old May 22, 2004 | 05:09 PM
Smooth-GSR's Avatar
Default Re: Hump Hose Necessary? (TurblowR)
I don't know if it would be necessary, there are probably tons of people running without one. If you don't have one already, then run it as is, if you find its poping off, then get one.
Old May 22, 2004 | 05:14 PM
TurblowR's Avatar
Default Re: Hump Hose Necessary? (Smooth-GSR)
should the t-clamps help alot?
Old May 22, 2004 | 05:17 PM
FOrSfEd's Avatar
Yes t-bolt clamps help a lot.
Old May 22, 2004 | 06:36 PM
JDubya's Avatar
Default Re: Hump Hose Necessary? (FOrSfEd)
Hump hoses are used when a connection isn't exactly straight on. It allows the pipes to flex more than straight couplings. It's like a flex pipe in an exhaust system...
Old May 22, 2004 | 06:56 PM
Garcia-Racing's Avatar
Even T-bolt clamps blow off under high boost. Just weld a bead on the end.
mike93eh
May 20, 2005 08:15 PM
SmasonGSR
Jun 25, 2004 08:56 PM
Rory Breaker
Oct 25, 2003 01:50 PM
Anubyss
Jun 10, 2002 04:27 PM
