hp restriction???????
Old Mar 31, 2007 | 09:44 PM
  #26
KeyserSoze's Avatar
Default Re: (b18sihatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch &raquo;</TD></TR><TR><TD CLASS="quote">i feel a gain will be seen with a tubular manifold upgrade over Log. spool is better with log but if WHP is his goal there are other variables to take into consideration when changing from log to tubular to help increase your spool times to insure a spool decrease if any minimual, will be had, thus increasing your whp over log</TD></TR></TABLE>
Man I really think your gonna have to explain that one again. At least the last half of your post anyway.
Old Mar 31, 2007 | 10:01 PM
  #27
blinx9900's Avatar
Default Re: (KeyserSoze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch &raquo;</TD></TR><TR><TD CLASS="quote">i feel a gain will be seen with a tubular manifold upgrade over Log. spool is better with log but if WHP is his goal there are other variables to take into consideration when changing from log to tubular to help increase your spool times to insure a spool decrease if any minimual, will be had, thus increasing your whp over log</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeyserSoze &raquo;</TD></TR><TR><TD CLASS="quote">Man I really think your gonna have to explain that one again. At least the last half of your post anyway. </TD></TR></TABLE>
yeah, agreed with keyser
Old Mar 31, 2007 | 11:20 PM
  #28
jarvis199's Avatar
ok i see everyones points, BUT, i have the same setup as many high 300 and low 400 whp guys, and its just not making the numbers or hte traps!!!
i was losing boost the last time at the dyno due to a torn wg diaphram, but i jsut dont understand why the hp flatlined like it did, it acted as if something else was restricting airflow, since their were no real ups and downs in the powerband...
right now im running a brand new tial diaphram, tial 10psi spring (big yellow) and a turbosmart mbc, and the boost no longer falls off, so i guess im going to still try and borrow an ebc and see how it goes with that...
Old Apr 1, 2007 | 06:41 AM
  #29
93turbo16's Avatar
Default Re: (jarvis199)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jarvis199 &raquo;</TD></TR><TR><TD CLASS="quote">
I think I explained this to you like 3 times. If you loose boost, you loose tq.. thus flatlining your HP. Just take a look at the damn Hp equation and you will understand.
Old Apr 1, 2007 | 06:57 AM
  #30
b18sihatch's Avatar
Default Re: (blinx9900)
what i was saying is that i think you stand to gain whp with a tubular manifold over log with minimul spool loss....and i feel its a give and take, if you make just say 50whp over log with tubular, you lose slight spool but gain 50whp which makes up for it
Old Apr 1, 2007 | 08:12 AM
  #31
jarvis199's Avatar
working on borrowing a greddy ebc today to see how much it helps guys
Old Apr 1, 2007 | 12:42 PM
  #32
jarvis199's Avatar
i got ahold of a new forge mbc today from a buddy,so hopefully that helps some, i know the turbosmart iwas running has been "modded" so im hoping its good now...
im going to invest in an avcr whe ni get the cash
scooba92hatch
Aug 13, 2004 09:35 AM
ziggity
Dec 5, 2003 05:53 PM
platinum00
Sep 11, 2003 07:23 AM
saso
Jun 28, 2003 03:11 PM
HX_Guy
Jan 23, 2002 03:34 PM
