hp question
Old Jan 30, 2006 | 09:29 AM
slows2k's Avatar
Default hp question
k i have an ls with eagle rods and ross 81.5 pistons im wanting to run about 13 to 15 psi right now i have
t3/t4 63 trim
2/5 downpipe
3 inch catback
obd1 ecu with hondata or crome not sure yet
650 rc's
255 fuel pump
aem fuel rail and p.r
act clutch and prolite flywheel
skunk 2 intake manifold
stock head
thats pretty much it...oh and its in a hf crx......how much hp do u think that will make and do u think i can run that safely with out blowing my motor?
Old Jan 30, 2006 | 10:32 AM
beerbongskickass's Avatar
Default Re: hp question (88lsturbocrx)
You can run as much power as your turbo and injectors will allow (injectors are good for about 400whp give or take). That LS head will be holding you back though. Oh and are you still running a cat? (your exhaust description just says catback) If so that will hold you back too. I'd go with crome because it will do that same thing hondata will do, except free. Tune your car well and it should be fine.
Old Jan 30, 2006 | 10:34 AM
slows2k's Avatar
Default Re: hp question (beerbongskickass)
yea still got the cat. do u think 15 is to high on stock sleeves on daily driver
Old Jan 30, 2006 | 10:44 AM
People have done 600+ whp on stock sleeves, so as long as you tune your car well you will be fine.
Mr.DC2TurBo
Apr 11, 2013 07:36 AM
94integragsr
Jun 15, 2006 06:41 PM
Civic Hx-T
Aug 26, 2005 10:57 AM
wisjdmhonda
Jan 7, 2005 11:57 AM
01ITR#700
Apr 10, 2004 02:48 PM
