hp #60-1
Old Oct 13, 2006 | 10:08 PM
racin jasin R's Avatar
Default hp #60-1
just wondering if any one could est. hp# 84mm sleeved .ls crank .gsr head.garrett 60-1.hopefully not to vage.just putting something together.
Old Oct 13, 2006 | 11:19 PM
paulzy's Avatar
mine made 1200hp uncorrected
Old Oct 14, 2006 | 10:19 AM
Default Re: (paul vang)
my exwife is a lee vang.you from st paul.how much hp did your 67 make
Old Oct 14, 2006 | 12:05 PM
paulzy's Avatar
Im not even done collecting parts yet dude. lolz
Old Oct 14, 2006 | 01:41 PM
B18 CYA's Avatar
84mm benson sleeved block, ls crank, and my gsr head, with a garrett 60-1 made 424whp/289 tq at 21 psi.
Old Oct 14, 2006 | 01:50 PM
Default Re: (B18 CYA)
thank you much
Old Oct 14, 2006 | 05:04 PM
ninesecrx's Avatar
Default Re: (racin jasin R)
Around 550whp
Old Oct 14, 2006 | 05:06 PM
fmfkid250's Avatar
20psi 480 whp
30psi 517 runs out of juice
Old Oct 14, 2006 | 07:10 PM
locash's Avatar
Default Re: hp #60-1 (racin jasin R)
I second the 550hp mark as the upper limits, thats what a buddies 84mm GSR with LS crank, and ball bearing Full-Race spec 60-1 did.. He works at Full-Race, his name is Aaron, call him for friendly advice, but be warned, he mumbles alot and he's hawaiian, so he always sounds high.
Old Oct 14, 2006 | 07:36 PM
Default Re: hp #60-1 (locash)
thank you i would take 400!!
Old Oct 14, 2006 | 09:49 PM
dunkd's Avatar
84mm gsr, stock port head, t3/60-1 .63/.70, 9:1
463 @ 20psi
510 @ 23psi
527 @ 25psi
didn't want to make anymore past there... so low/mid 500 is peak for this turbo I'd say.
Old Oct 14, 2006 | 11:18 PM
AlphaMike's Avatar
Default Re: (dunkd)
Here's mine:
https://honda-tech.com/zerothread?id=1194646
Old Oct 14, 2006 | 11:25 PM
IT'S ME DAVID's Avatar
NooB
Default Re: (AlphaMike)
About 450 whp.
Old Oct 14, 2006 | 11:37 PM
Default Re: (IT'S ME DAVID)
you guys have been helpful thanks again.
Old Oct 15, 2006 | 09:51 AM
V-SPEC 1's Avatar
Made 432whp on 93 pump and 540 whp 400 trq. 25 psi
Old Oct 16, 2006 | 07:22 PM
Default Re: (V-SPEC 1)
wow some of this # are crazy.
Old Oct 16, 2006 | 07:44 PM
nonvtecallmotor's Avatar
I made 501 @ 20psi with a t3/HIFI 60-1. 84mm LS/vtec.... It couldnt make an more power... no matter what boost. The car went 10.6 @ 137 in a street CRX
Old Oct 16, 2006 | 08:18 PM
SOHCboost's Avatar
I would like to try to make 600
Old Oct 16, 2006 | 08:48 PM
Dat1BVtecN's Avatar
yo ***** gonna be sick cuzzin! cant wait to check that **** out
Old Oct 17, 2006 | 11:27 AM
dunkd's Avatar
Default Re: (SOHCboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCboost &raquo;</TD></TR><TR><TD CLASS="quote">I would like to try to make 600 </TD></TR></TABLE>
with a t3 housing 60-1?
Old Oct 17, 2006 | 12:39 PM
SOHCboost's Avatar
oh no t4
Old Oct 17, 2006 | 02:26 PM
anothaRRR's Avatar
I made 561whp at 27lbs of boost on a 84mm GSR motor..
Same turbo on a 83mm GSR motor made around 630whp at like 31lbs of boost...
Old Oct 17, 2006 | 02:42 PM
dunkd's Avatar
Default Re: (anothaRRR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anothaRRR &raquo;</TD></TR><TR><TD CLASS="quote">I made 561whp at 27lbs of boost on a 84mm GSR motor..
Same turbo on a 83mm GSR motor made around 630whp at like 31lbs of boost...</TD></TR></TABLE>
t3 or t4 and what exhaust spec? .63 or .82
Old Oct 17, 2006 | 03:04 PM
Default Re: (dunkd)
.82
Old Oct 17, 2006 | 03:54 PM
T4eg's Avatar
430whp on 13-14lbs stock k20a2 long block
