Is this how you install this catch can?
Old Jul 13, 2016 | 05:00 AM
ramboPandA's Avatar
Default Is this how you install this catch can?
Hey guys. I have searched for how to install the catch can but what i mostly got was which system is better and what not. So my question is, is this how you basically install this catch can. The catch can has 3 ports. 2 on the side and 1 on the bottom. The 2 on the side run to the VC and the 1 on the bottom goes to the black box? Is there anything else I have to delete?
GO-AUTOWORKS Catchcan Kits
here is what is included :
B Series VC/Drain kit:
1 Aluminum S Can w/ 2 -10AN Inlet fittings, 1 -10AN drainback fitting and filter
3 90 degree -10AN fittings
3 -10 AN Straight fittings
1 10AN rear block conversion drainback fitting
9 ft -10AN hose
Old Jul 13, 2016 | 07:45 AM
boosted94gsr's Avatar
Default Re: Is this how you install this catch can?
You remove the black box and run the drain back port in the block where the black box was mounted, the other 2 are from the vc. If it was me I'd just skip the drain back part and only run the 2 vc ports. You can end up with water in your oil running the drain back system.
Old Jul 14, 2016 | 05:52 AM
ramboPandA's Avatar
Thanks and what do I do about those 2 lines that go from the black box to the motor. If i take out the box isnt that hole going to be uncovered?
Old Jul 14, 2016 | 06:24 AM
ramboPandA's Avatar
Should I just take those 2 lines leave the hose connected and put a screw in the hose?
Old Jul 14, 2016 | 12:48 PM
2kdrift's Avatar
Depends on which can you use, with the go auto kit
2 bungs get welded to the valve cover, you remove the black box and install the drain fitting included in the kit. The other 2 hoses that originally went to black box get capped off with vacuum line plugs.
running a drain back is debatable. B and R fittings sells catch cans in different styles. I went with a non drainback system, removed the black box and plugged the hole with a freeze plug
Kid-jdm-teggy
Feb 1, 2015 05:31 AM
GReddy SI
11
Nov 2, 2009 05:40 PM
sol-oto
Aug 18, 2009 10:12 AM
Kr4nG
Apr 7, 2009 05:27 PM
riceball777
Jan 4, 2006 12:24 PM
