How to wire in-tank fuel pump
Old May 26, 2005 | 02:04 PM
boostedeg22's Avatar
Default How to wire in-tank fuel pump
tryed searching could not find it. I'm trying to find out how to hard wire in tank fuel pump,
Old May 26, 2005 | 02:13 PM
dustin's Avatar
Default Re: How to wire in-tank fuel pump (boostedeg22)
You don't wire them, they plug in to your OEM connector.
Old May 26, 2005 | 02:40 PM
Default Re: How to wire in-tank fuel pump (dustin)
yeah i i know that but i want to hard wire and install relay for a higher voltage peak
Old May 26, 2005 | 02:47 PM
dustin's Avatar
Run a big gauge wire directly from the battery and use the OEM fuel pump wire to trip the relay then...
Old May 26, 2005 | 02:54 PM
someone told me theres a way to run the wire to the ignition so it is only actavated when acc is on not just running it directly to battery
Old May 26, 2005 | 03:29 PM
dustin's Avatar
If you trip the relay off the OEM pump wire, then the fuel pump runs whenever the ECU wants it to. The battery is the source of the power, but the connection is only made when the OEM pump wire gets power.
Old Jun 2, 2005 | 04:34 PM
Old Jun 2, 2005 | 08:10 PM
-Trinitron-'s Avatar
Kinda like the remote power wire on an amp...the power comes from the battery but it doesn't get power unless the ecu needs it to.
Old Jun 2, 2005 | 08:26 PM
Muckman's Avatar
Moderator in Chief
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedeg22 &raquo;</TD></TR><TR><TD CLASS="quote">...</TD></TR></TABLE>
hah that's the internet equivalent of a blank stare.
eg:R
Jun 16, 2014 07:15 AM
g2turbo
Jul 6, 2006 09:49 AM
Turbocivic94
May 7, 2006 05:04 PM
servion
Jun 3, 2004 07:54 AM
blumeany
Aug 2, 2003 06:48 AM
