how to wire an aem 3.5 bar?
ok ive been searching around for an hour or two and read through the faq's. i even have the instructions that came with it but i think they were written by bill shakspeare himself cuz there all *** backwards. anyway can some one tell me what wires go to what? set up is a 94 ls harness on a 95 gsr run by an aem ems 1040u box
http://www.aempower.com/images...r.pdf
Look at the picture that shows the connector pins. They are labeled Supply Voltage, Ground, and Output.
Look at your stock MAP sensor connector with the wires facing away (tabs should be above and on the right)
Left wire = Output
Middle wire = Ground
Right wire = Supply Voltage
BTW if you look in your stock MAP sensor (at least for a Civic/Teg/Lude) it has letters above the pins inside that cavity, V-G-O.
Left wire = Output
granturismonut2
Jul 7, 2009 03:48 PM
