How to tell if my injector went out?
Old 09-23-2007, 08:34 AM
a1320honda's Avatar
Default How to tell if my injector went out?
Ive got a set of PTE 1000cc injectors wired through a resistor box. My car is only running on 3 cylinders. Its got spark and fuel to the other cylinders obivously as well as spark on #4, but the #4 runner doesnt heat up at all and i can pull the injector clip and plug wire on #4 and it doesnt change the way it runs. In 3 cranks it puts down 165lbs of compression. So the only thing that could be left in an injector. Is there a way to check if an injector is bad. I tested Ohms and their all 2.6. I thought PTE injectors were supposed to be pretty reliable. Any input?
Old 09-23-2007, 09:15 AM
Princess
...esteban's Avatar
Default Re: How to tell if my injector went out? (a1320honda)
...just swap injectors from a known good running cylinder...it wont take long...any cel's?
Old 09-23-2007, 10:23 AM
alpha's Avatar
Like ...Lost said. Try the injector on another cylinder
Old 09-23-2007, 10:27 AM
ek_chris's Avatar
Or check voltage to the injector first (alot cleaner then swapping injectors) If you had to wire in new clips its a possibility you may have an open wire. It should read battery voltage.
Old 09-23-2007, 10:56 AM
mighty137's Avatar
ohm readings.....
Old 09-23-2007, 11:27 AM
Magik123's Avatar
Default Re: (mighty137)
injector balance test .... if u have the tools donno if u can rent em from anywhere but that is how to test injectors.
Old 09-23-2007, 12:26 PM
Chiovnidca's Avatar
Make sure it getting voltage. If it does, swap it with the injector next to it to see if the problem moves.
Old 09-23-2007, 01:06 PM
1cpu's Avatar
use a test light....
Corksil
10-31-2011 07:52 PM
turboteg2nv
12-02-2004 03:53 PM
HamiltonRex
07-12-2004 05:00 PM
Muckman
03-18-2004 07:11 PM
Quick Reply: How to tell if my injector went out?
