how to stop melting pistions
Old Jul 28, 2001 | 04:54 PM
SCsol's Avatar
Default how to stop melting pistions
hello there guys i keepp melting pistions in my b16 stock motor what can i do to stop it
my setup stock b16 motor with web turbo cams timing set at 17' then retards 5.5' after 3000 rpm with a br7es11 plugs but i keep melting motors what can i do to stop this please help me im running out of cash fast thanks for your help
Old Jul 28, 2001 | 05:32 PM
LEON's Avatar
Default Re: how to stop melting pistions (lowsol)
Can you provide some more details?
What does your fuel system consist of? How much boost are you running? What type of turbo? What exactly have you done to the engine internals?
Old Jul 28, 2001 | 05:37 PM
SCsol's Avatar
Default Re: how to stop melting pistions (LEON)
hey there my internals are stock and im runing about 10 psi with a talon turbo i have 380 injectors with a holly FI fuel pump thanks for the help with 94 octane fuel thanks
Old Jul 28, 2001 | 05:51 PM
KekeK-18's Avatar
I'll highly suggest you to get a stand alone system. A lot of ppls here will tell you tuning is everything, which is very true...A stock ecu just wont cut it, at least not for long ...a true stand alone will allow you to tune the fuel and timing a lot more accurate through out the whole rpm band. Its been more than a year now since I installed the DFI, I do a lot of autoxing and some road racing with my turbo and the motor still holding up strong.
VaporTrail's Avatar
New User
properly tuned engine management computer, or just lower your boost
b18bturbo's Avatar
you are probably running lean which increases cylider head temps and melting stock cast pistons.
Old Jul 28, 2001 | 06:07 PM
accordking's Avatar
Default Re: how to stop melting pistions (b18bturbo)
I would check out the your fuel pump then go from there. But a stand alone would be A good investment though.
Old Jul 28, 2001 | 11:23 PM
LsTurbo91's Avatar
Default Re: how to stop melting pistions (accordking)
Do you have a Egt gauge? I think that gauge would be the one to tell you if you are about to melt your pistons or not.
Old Jul 29, 2001 | 05:26 AM
turbotypeR@SPEC's Avatar
25 Year Member
take it to a dyno for some tuning.
Old Jul 29, 2001 | 06:51 AM
bruthaboost's Avatar
Have you considered hp coating? It will afford you a little more heat tolerance.
Hope things work out for you.
Old Jul 29, 2001 | 08:28 AM
TurboInteg95's Avatar
You didnt mention if you had any kind of FMU or rising rate regulator. With that small turbo on 10 psi you shouldnt be running that lean. How are you controlling the 380 cc injectors? those shouldnt run on a stock computer.
93civciv
Nov 4, 2005 07:43 PM
Shocka1998LX
Apr 4, 2004 02:55 PM
bumsta217
Oct 2, 2003 08:23 AM
bronzehatch
Jul 22, 2002 02:27 PM
