how to solder in an ecu
Old Dec 23, 2006 | 01:13 PM
integra3586's Avatar
Default how to solder in an ecu
i need to solder this 4 pin header in my ecu to i can run the NepTune RTP board. how difficult is it to do this? what do i use? a small torch or a thin point on a regular soldering gun?
this
needs to go
for this
i posted this in the FI section because i figure more boosted guys would know how to solder
Old Dec 23, 2006 | 01:17 PM
Civicman86's Avatar
There is some desodering tape you can buy at radio shack. Get some of that (it soaks up the soder already on the board, just put it on the hole but the soder gun tip on the tape and its like magic). Then put your part on and soder the joints.
Old Dec 23, 2006 | 01:25 PM
RC000E's Avatar
Default Re: (Civicman86)
Well, just be aware that if you overheat the board, a trace can easily lift. If that happens your screwed. You have to be careful with the heat...and cheap soldering guns/irons have no temp control. Also, be aware of the protective coating on the board. You can easily remove it with some break cleaner...it doesn't harm the board at all. Problem will be, you've removed the coating from surrounding areas as well. There is simply more to it that you need to be aware of. You can EASILY ruin your ecu...have no doubts.
I personally solder boards with a p.o.s. pencil sized iron. I have alot of success with a sharp tip, and some very fine solder. If you use the big thick stuff your going to screw it all up. Right tools for the job are the key.
Honestly, if your not sure about it, just pay someone locally. TV repair shops can easily do that job for cheap. That would only take me 15 min. with the cheap crap I use.
Old Dec 23, 2006 | 01:30 PM
Default Re: (RC000E)
yea im not sure if im gonna risk it. i may just pay someone to do it for me.
Old Dec 23, 2006 | 02:19 PM
ralph11sec's Avatar
Default Re: (integra3586)
that will be easy. just buy any desoldering tool. either desoldering gun, braid, or a sucking tool like a vaccuum thingy. just heat it up, and as soon as the lead goes liquid, suck them out.
ive done more than 100ecus already. you can DIY that.
you dont have to get those expensive temp controlled irons and stuff.
Old Dec 23, 2006 | 02:23 PM
Default Re: (ralph12sec)
how do i use the braid?
Old Dec 23, 2006 | 02:38 PM
i just finished, that was a lot easier than i thought it was gonna be
Old Dec 23, 2006 | 02:42 PM
ralph11sec's Avatar
congrats! thats also the process how to rechip an ECU you can now do rechipping ecus for your honda friends and charge them a 6pack. lol
Old Dec 23, 2006 | 05:50 PM
RC000E's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ralph12sec &raquo;</TD></TR><TR><TD CLASS="quote">congrats! thats also the process how to rechip an ECU you can now do rechipping ecus for your honda friends and charge them a 6pack. lol</TD></TR></TABLE>
A six pack...that's chump money. Don't take the process for granted...you will fry an ecu if you aren't careful.
Old Dec 23, 2006 | 08:03 PM
92HB_HB's Avatar
i've done numerous ECU chippings w/ the radio shack de-soldering gun and a regular soldering iron..
INfact today, i just desoldered my s200 socket and soldered in the components for my s300.. if you've done it before, its not that hard.. if you're new to electronics and soldering, find some old computer boards and start practicing..
Old Dec 23, 2006 | 08:08 PM
ralph11sec's Avatar
Default Re: (92HB_HB)
yep. i hate it when people discourage others to DIY. its really simple actually. im using a 1.50$ soldering iron and a desoldering sucker. works like a charm
Old Dec 23, 2006 | 08:18 PM
yup, im glad i didnt get discouraged. it was actually a lot easier than i anticipated.
Old Dec 24, 2006 | 11:35 AM
gunslinger's Avatar
From: Where thieves get shot in the face,, texas, usa
It is really easy to do also really easy to F it up. I learned the proper way to do it with junk ECU.
Old Dec 24, 2006 | 11:53 AM
iBrandon's Avatar
Default Re: (gunslinger)
Hakko desoldering gun! Can desolder a socket in seconds...i use to use the radio shack one..got tired of it..doesnt make a very clean desolder..
Wytek9
Engine Management and Tuning
Apr 19, 2009 02:38 PM
bravo831
Honda Civic (2001 - 2005)
11
Jan 20, 2007 08:59 AM
JolleyRanchaMan
Oct 11, 2006 09:24 PM
No-Gi
Dec 15, 2004 12:49 PM
tdc
Feb 2, 2003 04:25 PM
