how safe is it.....
its as safe as you make it.....which is best answer i can give you without knowing the rest of your setup(fuel management, injectors, internals,etc)
please include as much info with your questions as you can to get a better response from people.
Y8 would probably be more likely to fail from continuous high RPM operation that it would see boosted. If you don't want to spin a rod bearing I'd say keep the rev limit low.
no lol i have the built head and turbo kit .... but i wanna boost now and be buildin the bottom end right..... can i do boost on the old stock bottom end for awhile then put in the built bottom end....
You can do anything you'd like and it may work out but I wouldn't risk it. That's alot of miles on the old bottom. It could be in great condition or it could be ready to pop. If something goes south and damages that built head, you're in for even more $$$. Do it once, do it right.
Devine
Feb 20, 2006 04:07 PM
also did you mean build head in your original post?
