how to remove wastegate spring Deltagate???
Old Apr 20, 2004 | 10:18 AM
yusoslo's Avatar
Default how to remove wastegate spring Deltagate???
I want to pull the spring so I can break in my new motor.
I removed the 6 screws but no luck, it looks like a gasket is inbetween the top and bottom half of te wastegate.
Old Apr 20, 2004 | 11:02 AM
yusoslo's Avatar
Default Re: how to remove wastegate spring Deltagate??? (yusoslo)
up
Old Apr 20, 2004 | 11:05 AM
Nextelbuddy's Avatar
remove all the screw in the top.
make sure that your face is hovering right above the wastegate top
get a small screw driver and tap the wastegate top with the handle
count your teeth
Old Apr 20, 2004 | 11:52 AM
yusoslo's Avatar
Default Re: how to remove wastegate spring Deltagate??? (NextelBuddy)
that sounds painfull.
is there a gasket in there that i will need to replace if I remove the top?
Old Apr 20, 2004 | 11:53 AM
yusoslo's Avatar
if the wastegate spring is gone will all my exhaust gas route through the dumptube instead of the downpipe?
Old Apr 20, 2004 | 12:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yusoslo &raquo;</TD></TR><TR><TD CLASS="quote">if the wastegate spring is gone will all my exhaust gas route through the dumptube instead of the downpipe?</TD></TR></TABLE>
yea if u take the spring out then there is no pressure for the diaphram to build against so the wastegate will open the whole time
Zeusfire69
Apr 19, 2007 01:55 PM
HickamHatch
Oct 26, 2005 06:57 PM
Nextelbuddy
Oct 13, 2003 08:14 PM
