how reliable is turbo?
Old Apr 18, 2004 | 05:11 PM
vtec.com's Avatar
Default how reliable is turbo?
just need to know before i get the work done. how long will it last well tuned?
Old Apr 18, 2004 | 05:14 PM
Hoosier Daddy's Avatar
Default Re: how reliable is turbo? (vtec.com)
Depends on the setup, and how you treat it. If you do everything the right way and treat it fairly well, it should last forever...
Should*
Old Apr 18, 2004 | 05:15 PM
J337_UNIT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.com &raquo;</TD></TR><TR><TD CLASS="quote">just need to know before i get the work done. how long will it last well tuned?</TD></TR></TABLE>
with good fuel/engine/ignition management it could go a long ways..
other factors are how much psi you boost, how effecient the set up is, hwo often you beat on it.. many factors go into how long a turbo'd honda will last.
Old Apr 18, 2004 | 05:46 PM
warwagon's Avatar
the answer to your question is as long as a piece of string!!!
Old Apr 18, 2004 | 06:05 PM
Vtec92Civic's Avatar
Default Re: (warwagon)
lets jsut simply this . . . . a turbo setup is as realiable as you make it
that's the easiest way to look at it.
Old Apr 18, 2004 | 07:38 PM
m R g S r's Avatar
Default Re: (Vtec92Civic)
Some guy on here lasted 4 years with a fmu on a b series engine (I'm almost positive that it was 4 years). My gsr engine on the other hand lasted 3 months.
Old Apr 18, 2004 | 08:07 PM
ITSTOCK's Avatar
Default Re: (m R g S r)
depends how much money you got...
Old Apr 18, 2004 | 08:23 PM
Mad Cow's Avatar
Your question is very broad. Braod questions deserve broad answers. "turbo" can range from reliable to unreliable. Your car is only as reliable as your engine management.
Old Apr 18, 2004 | 08:58 PM
bottlefedb18c1's Avatar
I myself have seen turbo integra go in 20 miles. My old car that i dont have no more with for about 60,000 miles before i sold it and when i sold it it have about 190,000 miles.
Like said above it all depends on the tunning and setup
Old Apr 18, 2004 | 09:01 PM
xposter's Avatar
Aslong you do proper care of the car. The turbo should last a good time.
If you use a Ball-Bearing turbo it'll last 1.5-2x longer then a non-ball bearing turbo due to less moving parts.
Old Apr 18, 2004 | 09:18 PM
MikeMAN's Avatar
Default Re: how reliable is turbo? (Mr.Sleepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Sleepy &raquo;</TD></TR><TR><TD CLASS="quote">Aslong you do proper care of the car. The turbo should last a good time.
If you use a Ball-Bearing turbo it'll last 1.5-2x longer then a non-ball bearing turbo due to less moving parts.</TD></TR></TABLE>
less moving parts huh? i think it would last longer due to less friction because there certainly aren't less part, there are quite a few more, (*ball bearings vs. the 1 thrust bearing)
mike
Old Apr 18, 2004 | 09:28 PM
G
sh!t happens.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtec92Civic &raquo;</TD></TR><TR><TD CLASS="quote">lets jsut simply this . . . . a turbo setup is as realiable as you make it
that's the easiest way to look at it.</TD></TR></TABLE>
cant be explained better......
Old Apr 18, 2004 | 09:35 PM
dabrown's Avatar
Default Re: (G"UNIT)
My wife's is still rolling after a year or so.. Just do it right the first time and you will be set..
Old Apr 21, 2004 | 03:52 PM
i was rolling around for over 2 years sumer fall winter and spring
i couldnt complain
Old May 4, 2004 | 07:45 PM
4thgenlude's Avatar
Default Re: (bottlefedb18c1)
sorry, for takin over this thread, but for the people that have had turbos runnin for a long time, did you build the engine up? or are we talkin stock internals,
just need to know, sorry again
Old May 11, 2004 | 12:57 PM
4thgenlude's Avatar
Default Re: (4thgenlude)
no one?
Old May 11, 2004 | 01:00 PM
Phantom's Avatar
I've had stock internals (LS motor) boosted for more than 3 years...
Old May 11, 2004 | 02:04 PM
turboH22Aakkord's Avatar
you say... "fmu" .. what else did you and he have for your set up? and how much boost were you guys running? i'm just curious cause i'm trying to piece my management system together right now and i'm just trying to "get by" till i can go stand alone. but i have a jdm h22a and i'm plannin on running like 5.83lbs. could i get away with the fmu with that?? or do i "have" to run bigger injectors and an inline? thanks for your hlep!!
F22AU
Sep 30, 2007 04:54 PM
drew338
Mar 20, 2007 01:01 PM
PnoyJeff
Jan 26, 2005 03:22 PM
EJ8 GSR-T
Oct 30, 2004 04:48 PM
lunarcry
Aug 1, 2003 06:50 PM
