HOW TO PORT TURBO
Old Jun 10, 2009 | 05:41 PM
turbohatch96y7's Avatar
Default HOW TO PORT TURBO
i hate the search button now never helps..
well i want some info on how to port my turbo mainly the exhaust side..
do i port just the flapper vale or the whole exhaust housing..
thanks for any help
Old Jun 10, 2009 | 06:33 PM
mrbsponge's Avatar
Default Re: HOW TO PORT TURBO
what turbo is it? im assuming its an internally gated turbo. get you some bits that are gonna hold up to cast iron, get an air grinder and have at it, key word is taper not "hog out" going to far with cast iron will cause stress cracking and spider cracks.
why are you porting it? bad boost control?
Old Jun 10, 2009 | 06:37 PM
just heard it will be better and its externally ported
Old Jun 10, 2009 | 06:47 PM
TheShodan's Avatar
Moderator
That's because this isn't done.. In your case, most externally gated turbochargers don't benefit "porting" on the exhaust side the way your think. O2 housings and flapper openings for internal wastegates can be "ported", but not the exhaust housing.
Do not do this.
Old Jun 10, 2009 | 08:10 PM
HiProfile's Avatar
DSM guys 'port' their turbine housings, mainly for better turbine flow - not WG flow. They do all sorts of crap because their cars include a small turbo, while Honda owners generally start with a good turbo. In most cases, any grinding a n00b like you will do will harm the turbo. Its a far cry from adding an MSB blaster coil because "you heard it will be better", as housings aren't very cheap to replace.
Realisticly you shouldn't think about such mods until it noticably impacts performance.
Old Jun 10, 2009 | 08:21 PM
TheShodan's Avatar
Moderator
Even porting the O2 housings (not the turbine housings) are limited. After my 1ga DSMs, I've done this a few times, and it was better to just get the better turbo.
Old Jun 11, 2009 | 05:15 PM
okay yeah i actually heard this from some dsm guy i work with so my bad..
i did try to search around first before asking but didnt help but thanks for the help
boosted_LS95
Dec 9, 2009 02:52 PM
love2xlr8integra
Aug 11, 2004 09:43 PM
Rabid Machina
Mar 31, 2004 10:45 PM
cr-x si
Feb 6, 2003 04:51 PM
SickRevHrdTeg
Aug 18, 2002 02:19 PM
