How much is this worth???
Old Feb 10, 2009 | 10:13 AM
king06's Avatar
Default How much is this worth???
I recently bought an engine and turbo combo from a friend to eventually swap it into my car, but because of the lack of funds around the house i needs money. My question is, how much do you guys think i can get for it, my friend spend almost if not more than $6,000. Sorry if its in the wrong place, didn't know were else to put it since it is turbo.
Professionally balanced, blue printed an assembled
Turbo
  • OBX T3 cast iron turbo manifold
  • Tial Sport 38mm wastegate
  • Garret T3/GT40 “Blowzilla” .70A/R (500 to 600 hp)
  • Dump tube
  • 3 inch down pipe
  • Stealthemode oil return
  • Steel braided oil feed
Block
  • B16a block 81.5 bore
  • Sleeve guard
  • SRP/JE 81.5mm pistons 9.7:1 compression ratio
  • Eagle rods with ARP 2000 bolts
  • SRP/JE piston rings
  • ACL rod bearings
  • ACL main bearings
  • OEM thrust washer
  • B16a micro polished an balanced crank
  • Type R oil pump
  • Type R water pump
  • Type R timing belt
  • 81.5mm OEM headgasket
  • All new seals
  • OEM tapped oil pan
  • OEM Honda oil filter
  • Endyn breather box delete
  • Endyn Rear Breather Plugs(2)
Machine work
    • Bore
    • Hone
    • Deck
    • Hot tank
    • Micro polish
    • Balance
Intake Manifold
  • JG Eldelbrock Victor X
Head
  • 96 Integra P72 GSR
  • Valve springs Blox
  • Retainers Blox
  • BuddyClub cam gears
  • Type R valve cover
  • Milled
  • OEM seals
Old Feb 10, 2009 | 10:56 AM
jfoster's Avatar
Default Re: How much is this worth???
new or used?
Old Feb 10, 2009 | 11:11 AM
boostedcivicsir's Avatar
Mr. Badwrench
4. Tech related posts only
-No off-topic posts will be allowed. Use your common sense on this one. Do not create a thread with the purpose of something OT then later add something technical to it. There is also a forum specifically for Appearance/Cosmetic.
-Do not make threads listing your set-up then asking us what you should do next. It's your car, not ours. Everyone will list something completely different.
-Do not ask us how much your car is worth. Threads that offer to pay someone money for who ever diagnoses their problem are also not allowed.
-Do not start threads that can potentially start a flame war such as ‘Should I go with Company X or Company Y’? Blatantly obvious threads that are made to specifically show-boat a company’s product for free publicity are also not allowed unelss it has technical merit.
-No posts from companies listing public pricing.
-No bickering, flaming, name calling, or personal threats.
-No more calling out of people/shops/merchants for means of communication. Handle them In pm's. future threads will be locked or moved.
94civiccupew/b7
May 11, 2014 06:15 PM
Andy@AMR
Oct 9, 2012 12:34 PM
