how much psi does coolant have?
Old Aug 25, 2003 | 06:48 PM
2000vsm's Avatar
Default how much psi does coolant have?
ok i'm buying these hoses for coolant it says max 50psi.. so is coolant like 500 psi or something?
also what other hoses can i use.. can i use the CLEAR plastic pvc hose for coolant? or how about the clear with braided white threads.. it says up to 200psi but if coolant is 50000psi, i can't use it.. please tell me it's under 75000 psi
Old Aug 25, 2003 | 06:51 PM
inspyral's Avatar
Most radiator caps are usually rated at 13-16lbs. I can't see how any part of the cooling system could exceed that.
Old Aug 25, 2003 | 06:52 PM
inspyral's Avatar
Also, the hose you use needs to be rated for the heat and chemical properties of coolant mixtures, not just the pressure.
Old Aug 25, 2003 | 06:55 PM
GSRswapandslow
Guest
Posts: n/a
stick with RAD hose, or get some SS stuff that can support coolant too
the clear stuff won't work
Old Aug 25, 2003 | 08:56 PM
94TurboGSR's Avatar
Default Re: how much psi does coolant have? (2000vsm)
The clear stuff won't work, at the very least it will get cloudy and look bad. You should be more worried about the heat than the pressure. Have you ever taken off any of the coolant lines with the motor running? The fluid pours out, but it's no fire hose.
Old Aug 25, 2003 | 09:40 PM
2000vsm's Avatar
Default Re: how much psi does coolant have? (94TurboGSR)
ok so will those BLACK thicker "PVC/fuel" hose work?
Old Aug 25, 2003 | 10:26 PM
lazerus's Avatar
yes.
Old Aug 25, 2003 | 11:13 PM
oscarmayer's Avatar
dude, jsut get stock hose and get one of those "dress up kits" for it. it will make it look liek it's stainless steel....
lilshady6796
Jan 15, 2009 11:02 PM
MJOLNIRvTEC
Aug 18, 2008 05:37 PM
tigueremalo
Jul 10, 2006 07:16 PM
