how much power with 10 psi of boost?
Old May 18, 2004 | 10:29 AM
PY 01-0972's Avatar
Default how much power with 10 psi of boost?
didnt see this exact question in the search. with 10 psi and all the bottom end done right to handle the power. stock complete type R head intercooler and aftermarket tuning what should one expect to get to the wheels? I picked 10 psi so I could drive it daily with no worries and have it last along time. is 300 whp out of line for this set up. It would be 8.5 or 9 to 1 compression. thanks for all who reply.
Old May 18, 2004 | 10:35 AM
turbo*s2k's Avatar
Default Re: how much power with 10 psi of boost? (PY 01-0972)
It's really going to depend on your setup. IE turbo, and tuning... You should have no problem hitting 300 hp on 10 psi on your R....
Old May 18, 2004 | 10:37 AM
USDM 4G VTEC's Avatar
remember a good rule of thumb
u pick about ~8-10 whp with every 1psi
on a good conservative tune
Old May 18, 2004 | 10:42 AM
spark plugs.
Guest
Posts: n/a
Default Re: how much power with 10 psi of boost? (USDM 4G VTEC)
that sounds REALLY conservative? don't you think it's a bit more?
Old May 18, 2004 | 10:45 AM
PM-Performance's Avatar
Default Re: how much power with 10 psi of boost? (troublecodes)
you will hjave no probs if done right.
Old May 18, 2004 | 11:21 AM
Rory Breaker's Avatar
This depends on a ton of factors. If you have a more specific setup in mind, that would help.
27psi
Dec 23, 2009 04:15 AM
Rooftop voter
Jun 15, 2007 09:56 AM
OrangeBoost
Apr 17, 2006 05:03 AM
1990hondaHF
Aug 21, 2005 01:39 PM
xXx Justin xXx
Mar 20, 2003 09:23 PM
