How much nitrous can I run on my setup?
Old Jun 3, 2002 | 01:52 PM
EFing8's Avatar
Default How much nitrous can I run on my setup?
Here is my setup
LS/vtec
JE 9:1 81.5mm slugs
Eagle Rods
ITR valvetrain
ITR Cams
ITR Oil + water pump
I want to run 100 shot of NX Direct Port nitrous w/ their progressive controller. What else will I need to do?
Old Jun 3, 2002 | 02:08 PM
PM-Performance's Avatar
Default Re: How much nitrous can I run on my setup? (CND_CRX)
fuel pump and maybe a rail and some injectors. , obviously plugs and your good for a 100 shot easy.
maybe an igniton too , but not needed.
Old Jun 3, 2002 | 02:20 PM
EFing8's Avatar
Default Re: How much nitrous can I run on my setup? (itr206)
I was thinking a walbro intake unit and 310cc injectors. Do you think that i could possibly run 125shot? I want to start at 100 and if I think that the car is running good on that for acouple weeks then I want to move it to 125hp to lay the serious smack down. running some mid 12's for sure.
Old Jun 3, 2002 | 02:22 PM
littlebluecrx's Avatar
well with that compresion plenty with a direct port kitt, you could run a 150 shot, but you would have to ramp the shot up , if you started out with a 150 shot you probally could not hook up to save your life, just make sure you have a good fuel pump the right timming and colder plugs,also if you have it apart stainless steel valves would be a good investment, Jason
[Modified by littlebluecrx, 11:23 PM 6/3/2002]
Old Jun 3, 2002 | 02:24 PM
GSRwBOOST's Avatar
Default Re: How much nitrous can I run on my setup? (littlebluecrx)
I say no more than a 100shot.. and in a direct port setup..
Old Jun 3, 2002 | 02:43 PM
Default Re: How much nitrous can I run on my setup? (GSRwBOOST)
fuel and timing is deff gonan be key.
get it on the dyno and tune it for sure.
i say 100 shot will be cake. 125 i would prob go tops.
but the use of that prog controller will deff be needed. . . oh yea a clutch if you dont already have one.
Old Jun 3, 2002 | 03:33 PM
EFing8's Avatar
I have a clutchmasters stage 3. Would an AEM FPR cure my fuel problems? I am also planning on getting either the Jacobs Nitrous Mastermind and ignition or the NX progressive controller.
Old Jun 3, 2002 | 03:38 PM
dvp95's Avatar
Do you have new sleeves with the je pistons? I thought you needed new sleeves with forged pistons, unless its just the h22a.
PrecisionH23a's Avatar
Default Re: How much nitrous can I run on my setup? (dvp95)
make sure you tune it properly, post up your times when its all said and done
Old Jun 3, 2002 | 05:16 PM
Turbo Laser's Avatar
Default Re: How much nitrous can I run on my setup? (GudeH23a)
Can the stock sleeves hold that?
Old Jun 3, 2002 | 05:45 PM
CovertFI's Avatar
hahaha i hate that guy but that is one of the funniest pic's i have ever seen.
Old Jun 3, 2002 | 08:17 PM
PWRVTEC's Avatar
Default Re: How much nitrous can I run on my setup? (NOCARLOSER)
I would be more worried about the valves than the sleeves...
Old Jun 3, 2002 | 09:50 PM
redlinegsr's Avatar
definatley direct port....too much = disaster
redrex
Oct 21, 2014 09:28 PM
91integraLSVTEC
Sep 29, 2007 12:42 PM
speedyonez
Apr 22, 2003 08:10 PM
b18c-93
Feb 14, 2003 11:05 AM
KoRE
Aug 18, 2002 02:18 PM
