how much hp with my b18a???!!!
how much hp with my b18a+t25???!!!
I would like to know how much HP I could leave with this set-up ....yes...i do some research... ok...this is it...
b18a...bone stock...
t25
custom turbo manifold (look like inline pro one )
custom 2.5po down pipe /exaust
dsm 450cc
turbo smart or hks bov ,custom piping..
fmic 30X6 maybe
s-afc
others misc part....hose,gauges ,turbo timer...
at 8 and 11 psi....tunned...
how much you think I would leave with this set-up!? on the road in april... thanks guys
Modified by camocears at 2:46 AM 12/19/2003
t25
dsm 450cc
fmic 30X6 maybe
s-afc
Re: (camocears)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by camocears »</TD></TR><TR><TD CLASS="quote">spec is 130...</TD></TR></TABLE>
I think the base whp is only around 110-115 though...I might be a bit off though
Re: (camocears)
does anyone else think the turbo might hold him back a little? The turbo I think is going to limit his top range HP, and the fuel managment is going to take a small amount out of his entire curve, as far as potential.
-PHiZ
-PHiZ
if you dont care about your motor you can make as much horsepower as you want. I have heard of people running 300whp on a stock block, with the exception of a blockguard.
Re: (camocears)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by camocears »</TD></TR><TR><TD CLASS="quote">top...any suggestions or comment?! </TD></TR></TABLE>
comment: Eggnog tastes better with plenty of capt. morgan.
Re: (camocears)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by camocears »</TD></TR><TR><TD CLASS="quote">what is the top range hp for a t25??? 240?! and...can i upgrade my t25 to a t28 and keep the same turbo manifold??? </TD></TR></TABLE>
you should be because they only change the wheel "inside" the turbo when you upgrade to the 28....personally if you are looking to use a "small" "junkyard turbo" I'd go for a 14B TD04/5 off a 90-94 Eclipse, its proven to flow better than the 95+ T25.
wow...too many bumps for a stupid question.
T25 is the wrong turbo for that car. WAY too restrictive. That setup i would say 8psi=200whp 190tq, 11psi= 210whp and 200tq.
And since when do b18a's rev to 7400 or 7800? Id be looking for a replacement block if you plan on reving that high. And w/ a T25 at 8psi you def. wont be getting 240hp. im going to be boosting 11-12psi w/ a .63/.60/60 trim on my b18b1 and im thinking im going to make maybe 250ish WHP....no way hes going to make 10 less whp with that turbo.
and if i change my t25 wheel for a t28....the turbo gotta be less restrictive??? my t25 is ar80 , 63 ...................
and too many bumps for a stupid questions maybe...i want info's thats it...im not a turbo jesus...
