how much did it cost to build your engine for boost?
Old Oct 26, 2006 | 10:15 AM
Mr.Hankey's Avatar
Default how much did it cost to build your engine for boost?
Just wanted to know what everyone else spent on just the engine build. No turbo included. Mines cost $5k for everything in my engine including labor, parts, and installation.
Old Oct 26, 2006 | 10:26 AM
B18 CYA's Avatar
Roughly 3k US for me...
Old Oct 26, 2006 | 10:27 AM
droc327's Avatar
what engine and what did you have done??? i got my d16y8 completley built bottom for 700
Old Oct 26, 2006 | 10:35 AM
Mr.Hankey's Avatar
Well im planning on taking mines to 400-450whp so i pretty much replaced everything in my engine. Rods/Pistons/Sleeved/Clutch/Valves/ect. I know 700 wouldnt even pay for the parts for my build
Old Oct 26, 2006 | 11:08 AM
rmcdaniels's Avatar
Default Re: (Mr.Hankey)
I haven't added it all up, but it's gotta be over $7000, Dart block, custom RLZ head, custom Wiseco pistons, 95mm crank, cams, full assembly by Howard at RLZ, so much other stuff, and probably half that much again for a custom intercooled supercharger setup, and this is probably my 4th motor build. I spend way too much $ on this ****, but it's fun until it blows up
Old Oct 26, 2006 | 11:30 AM
92 CIVIC HATCH VX's Avatar
Default Re: (rmcdaniels)
h22 h2b gsr lsd tranny, dss stage 5, tilton twin disc, je 9.0 pist, eagle rods, all parts cryo treated and coated. port polish head, skunk 2 valve train. sc61, love fab mini, tial 50mm bov, 38mm waste, PTE 600 IC coated black, love fab Down pipe. 3inc back with 3inc vibrant muffler...... lots of little parts but total 15k wraped up in the project. It's something you got to have time for. parts break and more money to fix.
Old Oct 26, 2006 | 11:35 AM
Mr.Hankey's Avatar
hey, strickly engine build w/o FI. What did it cost without the FI/Exhuast parts?
Old Oct 26, 2006 | 11:45 AM
STEEZY_EG+DC's Avatar
Default Re: (92 CIVIC HATCH VX)
block ge sleeves $850
golden eagle head studs $120
wiseco piston $400
eagle rods $250
acl bearings $80
power enterprise timing belt $80
toga oil pump $200
honda water pump $65
moroso oil pan $125
headgasket $80
balance crank piston rods $150
the head
supertech vavletrain kit $600
port and polish $600
edlebrock mani $275
one fab mani $750
rpm throttle body$275
fuel rail $110
injectors $250
ctr cams $300
intake mani gastket $35
exhaust mani gasket $21.95
and thats not even adding turbo kit, fuel lines, twin disk clutch, tranny, engine management and guages. i know i already spent more then 10grand this summer prolly another 5 6 grand on top of the ten when all said and done.
Modified by blownlsvtecyo at 12:58 PM 10/26/2006
Old Oct 26, 2006 | 03:11 PM
Mr.Hankey's Avatar
Yeah i spent 5 and still need about 1 to finish up everything. Im probably forgeting somethings on this list.
This is what i have so far:
GE sleeved block
New crank
eagle rods, CP Pistons/Rings
ACL bearings
ACT Xtreme clutch kit
Supertech retainers/springs/valves
Cometic gaskets
blue printing / balancing
Machine work on engine
And cant forget Labor of taking the engine out, and putting it back in.
Old Oct 26, 2006 | 09:01 PM
4potnick's Avatar
lol. I drive a honda for what it is.........cheap!
d16y8 $free
eagles/vitaras $450
machine work $260
OEM honad parts bout $250
arp head studs. $100
headgasket $70
d15b head $free
Other odds and ends another $250, I guess
Maybe $1400.
I drive a honda as my cheap beater, hence the d-series and cheap price. My money goes into othe cars.
Old Oct 26, 2006 | 09:53 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: (4potnick)
Just engine parts no turbo.
Head:
Custom painted valve cover
NGK plugs/wires
Crower 402's --- Turbo-ls thanks again.
Crower springs
Crower retainers
Crower SS valves
Ferrea turbo valve guides
Ferrea valve seals
OEM head gasket set
Hondata IM gasket
GE cam cap - need to get
ARP head stud kit - need to get
ARP head studs
Head cleaned and resurfaced
New dowel pins
OEM cap and rotor
Block:
OEM bottom gasket set
Moroso Oil pan, street strip
OEM GSR oil pick up
OEM GSR baffle plate
ARP main studs
ACL thrust washers, main bearings, rod bearings
Micropolish crank - need to do
OEM oil pump
KMS billet engine girdle
CP 84mm piston set - need to get
Eagle rods/with ARP studs
OEM water pump
New timing belt
OEM tensioner - need to get
OEM A/C belt
PS belt
Alternator Belt - need to get
OEM rear main seal
OEM crankshaft pulley/key
ARP crankshaft bolt
New dowel pins
About a whole box full of OEM bolts/nuts/washers/gaskets ect...
GE sleeved to 84mm
Bored/honed - still need to do
Tranny LS:
Fidenza flywheel
Clutch - still dont know what 1 to get.
Might try to get my itr LSD to work. dont know yet.
B&M short shifter
New syncros - need to get
FR traction bars - need to get
About 3k+, Still got alot more to buy. About 2k more on the motor, fuel, cooling. And about 2k on the turbo stuff.
Old Oct 26, 2006 | 09:57 PM
Boner_Ben's Avatar
Eagle Rods= 300
JE pistons= 400
Bearings= 100
Machine Work= 300
Good enough to hold 567whp.
Old Oct 26, 2006 | 10:13 PM
01geeser's Avatar
New User
Default Re: (Boner_Ben)
cp's = 495
eagles = 280
GE HD sleeves/bore/hone/surface = 1000
acl's bearings = 100
arp headstuds = 115
Old Oct 26, 2006 | 10:15 PM
88_DX's Avatar
Ls short block $100
LS head $free
Delta cams $100
Head gasket $60
So around $300
Old Oct 26, 2006 | 11:49 PM
ValleySyder's Avatar
Default Re: (88_DX)
Darton Mids $1200
Wiseco 84 $350
Manley LS Turbo $475
ERL Girdle / ARP Main $350
ACL Race $100
Fluidampa $250
ARP Head $100
shortblock =$2900
Headgamez P&P $1300
Manley Spring & Retainer $250
Manley Vales $250
CTR cams $400
head = $2000
Modified by ValleySyder at 1:53 PM 11/17/2006
Old Oct 27, 2006 | 04:08 AM
TurbodTegSfaria's Avatar
Default Re: (ValleySyder)
its definetly not cheap to build 400+hp hondas,im on my 3rd build and this time i did it right and actually spent the extra money.. but man does it suck when they blow
a good 8 grand under my hood with all the builds
Old Oct 27, 2006 | 05:46 AM
b18sihatch's Avatar
Default Re: how much did it cost to build your engine for boost? (Mr.Hankey)
my brakedown is like this
500.00 sleeves
500.00 je pistons
600.00 crower h beam rods
1600.00 for parts
rod bearings
main bearings
machining
sleeving
deburr pistons
blue printing
rotating & balancing rotation assembly
other odds and ends and complete assembly
2200.00 plus parts
3800.00+ here
Old Dec 7, 2010 | 02:50 AM
criticallistenp's Avatar
My build was all motor and it has been years in the making... the answer is TOO MUCH! lol
Old Dec 7, 2010 | 05:10 AM
darkvader0's Avatar
I budgeted $2000 for my build in 2003 and came in under budget lol. I keep my builds simple tho.
Benson's Sleeves at 84.5mm
Endyn Pistons (84.5mm)
Crower rods
new OEM bearings
upper/lower gasket sets
< $2000
Rest of everything is all stock. Stock GSR manifold and TB even lol. Oh I stopped by Endyn and he opened up the combustion chambers on my head to match 84.5mm bore, that is all.
Old Dec 7, 2010 | 02:52 PM
megomaniac's Avatar
LABOR:
STRIP, DEGREASE BLOCK
CHECK MAIN HOUSING BORES, BEFORE & AFTER SLEEVING
CLEAN & MIC CRANKSHAFT
MICRO POLISH CRANKSHAFT
CLEAN & CHECK NEW PISTONS & RODS
MACHINE BLOCK FOR DARTON SLEEVES
FINISH BORE & HONE BLOCK W/ TORQUE PLATE
SQUARE DECK BLOCK FOR MLS GASKET
COMPUTER SPIN BALANCE CRANKSHAFT
INSTALL PISTONS ON RODS
R & R OIL PUMP
CLEAN & CHECK CYLINDER HEAD
VALVES GOOD ON HEAD, NEEDS MILLING
FINAL WASH BLOCK FOR ASSEMBLY
FILE FIT RINGS
CLEAN ALL PARTS & ACCESSORIES
BLUEPRINT ASSEMBLE ENGINE W/ HEAD
LABOR = $2200.00
PARTS LIST:
DARTON SLEEVE KIT
CP TURBO PISTONS W/ RINGS
EAGLE CONNECTING RODS
ACL RACE BEARINGS
MAINS, RODS. & THRUST
ARP MAIN/HEAD STUD KIT
BALANCE SHAFT ELIMINATOR KIT W/ INSTALLATION
PARTS = $2150.00
TOTAL COST W/ TAX = $ 4612.00
H22
Old Dec 7, 2010 | 03:16 PM
boostedcivicsir's Avatar
Mr. Badwrench
a 4 year old thread for this? wow. please stop post whoring.
Old Dec 7, 2010 | 03:37 PM
sc34dc4's Avatar
It's been an epidemic lately. I see at least 2 old threads a day that are bumped.
MalcolmV8
Nov 10, 2012 05:58 AM
94civicB16
Jun 1, 2003 08:06 PM
accordfreak
Feb 4, 2002 03:59 PM
vpforeva
Jan 16, 2002 01:55 PM
Adampops
Jan 5, 2002 07:30 PM
