How Much Copper Spray
Old Dec 30, 2007 | 10:17 PM
Dunc's Avatar
BCICAN
Default How Much Copper Spray
How much copper spray do you guys (those of you who do use it) put on your headgaskets? Do you use only one coat, two coats, five, the whole can, etc?
Old Dec 30, 2007 | 10:53 PM
CoreyR's Avatar
Default Re: How Much Copper Spray (Dunc)
i usually do 3+ coats, until the gasket has a solid coating on it.
Old Dec 31, 2007 | 03:39 AM
non-VTEC's Avatar
if both the head and block are freshly machined flat you only need a very light coat of the spray on the gasket.......or even none at all.
a couple light coats is enough........no need to overdue it..........the more you put on the more chance of the excess being squeezed out between the head/block into some oil passages and plugging something up
Old Dec 31, 2007 | 04:59 AM
cbustuner's Avatar
Default Re: How Much Copper Spray (CoreyR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoreyR &raquo;</TD></TR><TR><TD CLASS="quote"> until the gasket has a solid coating on it.</TD></TR></TABLE>
Old Dec 31, 2007 | 10:44 AM
Joseph Davis's Avatar
I don't use it.
If I want copper in there I o-ring the block.
Old Dec 31, 2007 | 10:58 AM
SpoolnG2's Avatar
Default Re: (Joseph Davis)
I used to use 2-3 coats. Just so theres a solid layer on there.
Old Dec 31, 2007 | 04:04 PM
H.A.R.T B18C1EG6's Avatar
Default Re: (SpoolnG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 &raquo;</TD></TR><TR><TD CLASS="quote">I used to use 2-3 coats. Just so theres a solid layer on there. </TD></TR></TABLE>
same
Old Dec 31, 2007 | 07:14 PM
Kevin's Avatar
Default Re: (H.A.R.T B18C1EG6)
I've always gone by color, just making sure it's got a nice even coat.
Old Dec 31, 2007 | 09:24 PM
Hybrid_Coupe's Avatar
i never use any...never have headgasket problems...like stated above...if i want copper there...ill o-ring the block
Old Dec 31, 2007 | 09:25 PM
T4eg's Avatar
i dont use it
Old Dec 31, 2007 | 09:43 PM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joseph Davis &raquo;</TD></TR><TR><TD CLASS="quote">I don't use it.
If I want copper in there I o-ring the block.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid_Coupe &raquo;</TD></TR><TR><TD CLASS="quote">i never use any...never have headgasket problems...like stated above...if i want copper there...ill o-ring the block</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T4eg &raquo;</TD></TR><TR><TD CLASS="quote">i dont use it</TD></TR></TABLE>
Ok, sooo if you don't use it then you aren't providing any useful information which means you need not post.
Old Jan 1, 2008 | 06:05 AM
Default Re: (Dunc)
It might not be the answer you want to hear, but spraying some sticky crap that attracts every bit of microscopic debris floating in the air to party on your headgasket sealing surface is counterproductive.
Sorry to spit the truth as we see it to you. You may think this is your thread, but it's really a public posting in a public tech forum that other people are going to see and refer to in the future. I want to make sure it has some accuracy or failing that some differing opinions so the discerning reader can make up their own mind from all available information. I'd call that useful.
Then again I could be a smartass and tell you to read the instructions on the can... which would be the correct answer if the stuff works as advertised. Common sense is king, but some people insist on not looking in plain sight for their answers.
Happy New Year, bro.
Old Jan 1, 2008 | 08:02 AM
Desir Performance's Avatar
We usually use about 2-3 coats on both sides, letting the copper dry for about 1min between coats.
Old Jan 1, 2008 | 09:27 AM
rico91stang's Avatar
I ask Twitter, not xtrac1
Community Builder
Community Influencer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joseph Davis &raquo;</TD></TR><TR><TD CLASS="quote">It might not be the answer you want to hear, but spraying some sticky crap that attracts every bit of microscopic debris floating in the air to party on your headgasket sealing surface is counterproductive.
Happy New Year, bro.</TD></TR></TABLE>
And that is that. Best post of '08 so far.
Old Jan 1, 2008 | 10:13 AM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joseph Davis &raquo;</TD></TR><TR><TD CLASS="quote">I want to make sure it has some accuracy or failing that some differing opinions so the discerning reader can make up their own mind from all available information. I'd call that useful.</TD></TR></TABLE>
It's not a thread debating whether or not I want to use the stuff or how effective it works. This is a thread asking how much others are using (and yes I also read the can). If others in the future are concerned about getting accurate information from this thread alone then they are flat out stupid. They should do their own research in other threads that debate the effectiveness....then come to this one and read about the quantity most others are using.
Old Jan 1, 2008 | 10:49 AM
boosstboy's Avatar
Default Re: (Dunc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc &raquo;</TD></TR><TR><TD CLASS="quote">
getting accurate information from this thread alone then they are flat out stupid. They should do their own research in other threads that debate the effectiveness </TD></TR></TABLE>
so why are you asking how much everyone uses? some use a little some use the whole can. not very accurate, you should take your own advise. i know 1 or 2 who used copper spray and did not use the whole can, just 2 or 3 light coats. the purpose of this stuff is not to lower compression or use the spray as a head gasket itself, it's used to cover MINOR imperfections in the head or blocks surface. a good question to ask is if i get some from globing it on, in the oil system and it goes through the oil pump will it pit the bearings? i don't have the answer to that because i don't use it, but would be interesting to see a response from real/professional engine builders.
Old Jan 1, 2008 | 11:58 AM
Runnerdown's Avatar
Default Re: (boosstboy)
The black nitrile coating already on the headgaskets is suppose to do the same thing. If the surface is not up to snuff, then i'll usually spray a <U>very</U> light coat. For the quick and dirty jobs, or one where surfacing blocks or heads is not an option I think it can serve it purpose ok.
Old Jan 1, 2008 | 12:12 PM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosstboy &raquo;</TD></TR><TR><TD CLASS="quote">so why are you asking how much everyone uses? some use a little some use the whole can. not very accurate, you should take your own advise. i know 1 or 2 who used copper spray and did not use the whole can, just 2 or 3 light coats. the purpose of this stuff is not to lower compression or use the spray as a head gasket itself, it's used to cover MINOR imperfections in the head or blocks surface.</TD></TR></TABLE>
Yea I know the purpose of the copper spray haha. If I wanted to lower the compression then I'd change the pistons. The purpose for me asking is that I want to see how much others are using of the stuff that have the same type of engine as me. It's called gathering as much info as I can and then making my own educated conclusions from what I read.
Old Jan 1, 2008 | 07:05 PM
T4eg's Avatar
Default Re: (Dunc)
Yea I know the purpose of the copper spray haha. If I wanted to lower the compression then I'd change the pistons. The purpose for me asking is that I want to see how much others are using of the stuff that have the same type of engine as me. It's called gathering as much info as I can and then making my own educated conclusions from what I read.</TD></TR></TABLE>
ok then dont use it, it would save u from tryin to clean that crap off everything when u take it apart next time
Old Jan 1, 2008 | 07:34 PM
Garcia-Racing's Avatar
I use it in almost every motor, including those with fresh surfaces. 2 coats usually.
Old Jan 1, 2008 | 07:39 PM
gogunkergorilla's Avatar
Well I never use copper spray anymore since I found Hylomar spray, its much better for sealing and its designed for race engines. If you've had the deck and head resurfaced perfectly flat, then you should not use it. If its only off by 0.001-0.002 then spray 2-3 light coats.
Old Jan 1, 2008 | 07:42 PM
xsi-t's Avatar
Default Re: (T4eg)
if all surfaces are flat and even its not needed. honda doesnt use it why should you??
Old Jan 1, 2008 | 07:44 PM
I don't believe honda has any intentions on making high horsepower motors like we do. But what do I know about making any kind of power....?
Old Jan 1, 2008 | 07:52 PM
xsi-t's Avatar
Default Re: (Garcia-Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garcia-Racing &raquo;</TD></TR><TR><TD CLASS="quote">I don't believe honda has any intentions on making high horsepower motors like we do. But what do I know about making any kind of power....?</TD></TR></TABLE>very true but copper spray is a bandaid
Old Jan 1, 2008 | 07:53 PM
Default Re: (xsi-t)
ok
