how much boost will this hold?
Old Aug 25, 2003 | 10:08 AM
crx1856's Avatar
Default how much boost will this hold?
b16:
je 9.5:1 pistons
ge 84mm bore sleeved block
3 angle valve job
stock valves
portflow springs/retainers
gsr cams
all new pumps gaskets bearings
hondata s200b
255 fuel pump rc 550 injectors
i'm going to get this motor tuned next week, i was just wondering how much boost this motor will take? i'll be using a turbo xs dual stage boost controller.
Old Aug 25, 2003 | 10:29 AM
t616
Guest
Posts: n/a
Default Re: how much boost will this hold? (crx1856)
how much boost its going to make depends on your setup and what psi range your trying to target, as far as how much it can hold should be roughly 30 psi.
Coolero
23
Dec 10, 2009 02:55 PM
evilk
May 25, 2005 06:39 PM
the DA in HONDA
Sep 1, 2004 08:55 PM
1sick4door
Dec 9, 2001 05:38 PM
