how much boost on stock motor
Old Nov 16, 2005 | 08:47 PM
goldencivic89's Avatar
Default how much boost on stock motor
hey guys new to the board here but i was wonder how much boost i can run on a stock jdm b16a motor with injectors fuel and fuel rail everything else stock besides the turbo kit i'm wonder becuase i'm lookin into turboin my motor
Old Nov 16, 2005 | 09:04 PM
Pee Wee's Avatar
Default Re: how much boost on stock motor (goldencivic89)
0 boost. you need some kind of fuel managment.
https://honda-tech.com/zerosearch
Old Nov 17, 2005 | 03:25 AM
ReDHaTcHyGuy's Avatar
Default Re: how much boost on stock motor (EF8opey)
Got a buddie with a stock itr running 15psi on a precision PT-70 running 10.98's...... he also a certifed AEM tuner and doesn't really care if he blows it or not but he's been running it like that for a while .. its all in the tune...........lol...........thats on race gas also
Old Nov 17, 2005 | 09:11 AM
bnut510's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goldencivic89 &raquo;</TD></TR><TR><TD CLASS="quote">hey guys new to the board here but i was wonder how much boost i can run on a stock jdm b16a motor with injectors fuel and fuel rail everything else stock besides the turbo kit i'm wonder becuase i'm lookin into turboin my motor</TD></TR></TABLE>
first of all... like homie said up there.. u need engine management but thats an easy step to come across... just get a chipped p28 and run it with crome or uberdata.... those programs are free. if u got some money to spend, id go with a hondata s300. as far as your boost... what kind of hp goals are u looking at? lets just say u have a t3/t04e turbo... with that turbo and that ecu combo... u can do about 9 max id say safely... i wouldnt go above 9psi tho since the ecu cant handle it.
Old Nov 17, 2005 | 11:00 AM
a1320addict's Avatar
Default Re: how much boost on stock motor (bnut510)
your question is pretty vague...its more of a question how much horsepower the block can take. but most importantly, ultimate power output is going to 2) depend on the tune b) rely on the tune.
invest in some real engine management and go from there.
Old Nov 17, 2005 | 01:06 PM
i'm looki at the peak boost kit but i was wonder how much stock i don't have money right away for a the s300 so i am wonder how much on a stock ecu with just injectors and the peak boost b series kit or the drag kit i can't decide on which one ?
Old Nov 17, 2005 | 01:30 PM
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bnut510 &raquo;</TD></TR><TR><TD CLASS="quote">
u can do about 9 max id say safely... i wouldnt go above 9psi tho since the ecu cant handle it. </TD></TR></TABLE>
Why?...please enlighten us all
Old Nov 17, 2005 | 01:59 PM
bnut510's Avatar
Default Re: how much boost on stock motor (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">
Why?...please enlighten us all </TD></TR></TABLE>
ehh just my 2 cents... not sayin i was right with that quote... so maybe i shouldnt have said it... but i was running 9 psi with a p28 chipped on crome... and i was told by more than a few people i shouldnt go over 9 psi just cuz i might expletive something up.. maybe they got a ***** between theyre legs and i happenned to listen to them.
Old Nov 17, 2005 | 02:00 PM
Mohsin's Avatar
stock map sensor only supports max 11psi? correct me if im wrong
Old Nov 17, 2005 | 02:06 PM
bnut510's Avatar
Default Re: (Mohsin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mohsin &raquo;</TD></TR><TR><TD CLASS="quote">stock map sensor only supports max 11psi? correct me if im wrong</TD></TR></TABLE>
exactly what i was thinkin but i didnt wanna say nuttin cuz i aint sure..
Old Nov 17, 2005 | 02:45 PM
adseguy's Avatar
Default Re: (bnut510)
correct, but you can tune the last couple columns conservative so that you can push 12, maybe 13PSI if you wanted...then all you need is $60 to buy a better map sensor and you're ready to go. I just thought you were implying that over 9PSI was dangerous to the motor.
so like 12-13 psi with a new map sensor is safe on a stock motor?
Modified by goldencivic89 at 4:52 PM 11/17/2005
Old Nov 17, 2005 | 03:26 PM
bnut510's Avatar
Default Re: (adseguy)
correct, but you can tune the last couple columns conservative so that you can push 12, maybe 13PSI if you wanted...then all you need is $60 to buy a better map sensor and you're ready to go. I just thought you were implying that over 9PSI was dangerous to the motor. </TD></TR></TABLE>
o nahh i didnt mean it like that.. all good
Old Nov 17, 2005 | 06:54 PM
all go teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goldencivic89 &raquo;</TD></TR><TR><TD CLASS="quote">so like 12-13 psi with a new map sensor is safe on a stock motor?
Modified by goldencivic89 at 4:52 PM 11/17/2005</TD></TR></TABLE>
like the rest of the guys said, if you have a crappy tune then dont expect the motor to last long, but if you have a good tune, dont drive the **** out the car, and make sure you take care of the car, then i guess you could......
Old Nov 17, 2005 | 07:17 PM
adseguy's Avatar
I should re state what I meant. I thought it was a little confusing when I wrote it. The question isn't how much boost really, but horsepower. Keep it under 300 at the wheels and get a reputable tuner. The stock map sensor will only read up to 10.4 PSI, but if you make the last couple columns very conservative you can boost 12-13 lbs pretty safely without much sacrafice in performance in the 10 PSI range. The map sensor will just max out as the boost keeps going...get it?
I have boosted 18PSI on my stock motor for 20k miles now. Zero problems. I beat the **** out of it too, but take care of any little problems that arise. Read up...PSI doesn't kill engines, tuners and horsepower do
Old Nov 17, 2005 | 07:41 PM
G
sh!t happens.
What turbo will you be running? I ran 12psi on a stock jdmb16 sc61
Old Nov 17, 2005 | 07:52 PM
Pee Wee's Avatar
Default Re: how much boost on stock motor (G"UNIT)
if all he really has is a fuel rail and injectors he is screwed. i dont even think his car will idle without some managment let alone actually run properly
Old Nov 17, 2005 | 08:54 PM
i think i've decided on the drag 57 trim turbo kit and all i'll have is everything in the kit and fuel rail and injectors to start with then i'm gonna build from there
Old Dec 4, 2014 | 07:55 PM
Nlevy10's Avatar
I ran 16 PSI on stock B18A1 precision 6266 with the .68 turbine housing. made over 350whp all summer no problem
Old Dec 5, 2014 | 01:26 AM
NotARaCist's Avatar
I never narc'd on nobody!
You also just bumped a 9 year old thread. You also bumped an 11 year old thread. and a 1 year old FS thread.
Old Dec 5, 2014 | 05:54 AM
Schister66's Avatar
Man U FTW
How do people even find these threads?
blackfoot
Jan 22, 2006 08:01 AM
89 EF Si
Feb 12, 2005 11:35 PM
RobbieG35
Jun 11, 2004 01:59 PM
sleepz
Jan 12, 2004 07:15 PM
PsshSound
Jun 3, 2003 01:02 PM
