how much boost on stock head bolts????
Old Dec 8, 2002 | 08:07 PM
hybridb18's Avatar
Default how much boost on stock head bolts????
how much boost can stock ls headbolts and gasket hold???? Im putting my turbo on this week, and the wastegate has a 9## spring in it. Will the stock headbolts hold this amount of boost??? What is the worst thing that will happen if i dont change them out? Just blow the head gasket, or will it do some serious damage to the engine. Im planning on getting arp's but i am gonna get another longblock with less miles on it soon, and dont want to waste the money on this motor. Thanks
Old Dec 8, 2002 | 08:28 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: how much boost on stock head bolts???? (hybridb18)
we have run 30psi on our h22 with stock headbolts before they released arp's for the h22. Doesnt mean you can do it all the time but it lasted a few passes w/o problems. the headbolts are only like 120.00 and you can use them in your new motor, why not invest in them now??
Old Dec 8, 2002 | 09:30 PM
hybridb18's Avatar
Default Re: how much boost on stock head bolts???? (MotorMatrix.com)
but, what type of damage are we talking about if i blow the gasket while pushing 9psi. any serious engine damage????? or just a blown gasket????? Would there be any way that soooo much coolant would get in the cylinders and cause the engine to hydro lock??? Anyone out there blown headgasket under boost??? what happened to the motor?
Old Dec 8, 2002 | 09:40 PM
jinxproof99's Avatar
New User
i had stock head bolts on my car. b18c1. 500+ to the wheels.
Old Dec 8, 2002 | 10:35 PM
ion_four's Avatar
I'm getting the feeling that you think that the headbolts/gasket are the weakest link in your engine. this is not the case. You will destroy your ringlands and then break a rod WAY before the headgasket or bolts go. 10psi seems to be the magic number for a D-series block, and probably not too much more for a b-series. as the broken record says: "it's all about the tunining"...you can blow your motor with 5psi, easy, if you don't know what you're doing with your fuel and timing.
Old Dec 8, 2002 | 10:40 PM
PrecisionH23a's Avatar
another good thing about the arp headstuds are that you can use them over and over and over again. on stock head bolts, it is recommended that you replace them whenever you take them out.
Old Dec 8, 2002 | 10:58 PM
camp1320.com's Avatar
Default Re: how much boost on stock head bolts???? (GudeH23a)
i have seen 15lbs on stock head bolts at about 400hp to the wheels.. but you should change it with anything more than 15lbs and 400hp just to be on the safe side..
Old Dec 9, 2002 | 10:05 AM
boostin b16's Avatar
Default Re: how much boost on stock head bolts???? (camp1320.com)
i personally have seen 1.3bar(19.11psi) on many race nights without a problem, i have stock headbolts and a 3mm headgasket on a b16. other things are gonna go way before the headbolts. but possibly the gasket
Old Dec 9, 2002 | 11:36 AM
st00pid's Avatar
Default Re: how much boost on stock head bolts???? (boostin b16)
20 psi and a 50 shot so far on stock LS head bolts.
Old Dec 9, 2002 | 01:31 PM
hybridb18's Avatar
Default Re: how much boost on stock head bolts???? (st00pid)
okok, i guess ill run the stock bolts for now, but what kind of damage will there be if the gasket blows??? Hydrolock??? crack the head/block???? Any opinions
Old Dec 9, 2002 | 01:38 PM
HXMan's Avatar
:shakeshead:
If the gasket blows and you keep driving..you could warp your head from overheating...bout all I can think of right now.
Old Dec 9, 2002 | 03:13 PM
TeStUdO's Avatar
Default Re: how much boost on stock head bolts???? (HXMan)
warp the head and drive around with alot of smoke coming out of your car. you shouldnt be worried about the head gasket and bolts you should be worried about pistons and rods.
jaxx4k
Apr 2, 2005 05:11 AM
D-meet07
Nov 4, 2004 06:29 PM
u_tal
Oct 12, 2004 05:00 PM
teamrocket si
Jul 6, 2002 12:52 AM
Charles B.
Oct 29, 2001 09:26 AM
