How Much Boost.......
Old Jan 12, 2007 | 10:18 AM
jarven93's Avatar
Default How Much Boost.......
How much boost can a D16z6 block hold before needing to be sleeved . i have built the internals up .... rods pistons crank. but not sleeved how much boost can i run??? i want to hit 15lbs
thanks
Old Jan 12, 2007 | 10:20 AM
zexxbo's Avatar
Default Re: How Much Boost....... (jarven93)
i wouldnt go above 280whp- but thats just me. those things break mang, ive seen it
Old Jan 12, 2007 | 10:21 AM
jarven93's Avatar
Default Re: How Much Boost....... (zeimbo)
well i just want to know how much boost i can run on a unsleeved block
Old Jan 12, 2007 | 10:25 AM
zexxbo's Avatar
non-gt series: 14lbs
gt series: 8lbs
Old Jan 12, 2007 | 10:42 AM
DaveF's Avatar
685893438745975 LBS
Old Jan 12, 2007 | 10:50 AM
Schister66's Avatar
Man U FTW
Default Re: How Much Boost....... (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">non-gt series: 14lbs
gt series: 8lbs
Quit pulling numbers out of your *** and spreading bad information!
I think the Jeff Evans tuned stock internal D making 375whp on 28psi proves your theory wrong.
Sleeving is generally a peace of mind thing. There isn't a set PSI or horsepower where you MUST have sleeves. Most people wouldn't make more than about 400whp on a D or 500whp on a B without using sleeves just to be safe. Personally i'm going to sleeve my GSR engine once i rebuild so that i have nothing to worry about....regardless of the power i plan to make.
Old Jan 12, 2007 | 11:45 AM
Topdawgg's Avatar
Default Re: How Much Boost....... (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">685893438745975 LBS </TD></TR></TABLE>
exactly..
id be more concerned about how much power you want, and then determine what boost will get you there...
it DEPENDS ON THE TURBO..
Old Jan 12, 2007 | 12:07 PM
SovXietday's Avatar
Default Re: How Much Boost....... (Topdawgg)
There are so many people making 400whp on stock sleeves now, it's all about the tune.
Old Jan 12, 2007 | 12:21 PM
snaileg's Avatar
it is all about the tune like everyone else has said like right now im still on stock sleeves but with a piston/rod setup on a b series and im pushing 20psi on somenights and about 14psi daily
Old Jan 13, 2007 | 02:24 PM
zexxbo's Avatar
Default Re: (snaileg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">Quit pulling numbers out of your *** and spreading bad information!
Sleeving is generally a peace of mind thing. There isn't a set PSI or horsepower where you MUST have sleeves. Most people wouldn't make more than about 400whp on a D or 500whp on a B without using sleeves just to be safe. Personally i'm going to sleeve my GSR engine once i rebuild so that i have nothing to worry about....regardless of the power i plan to make.</TD></TR></TABLE>
i didnt pull them out of my ***, i was being sarcastic and partially honest at the same time.
if youre using a gt series turbo, anything above <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zeimbo &raquo;</TD></TR><TR><TD CLASS="quote">8lbs</TD></TR></TABLE> is gonna yield over 400hp
and if youre using like a 60-1, anything above <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zeimbo &raquo;</TD></TR><TR><TD CLASS="quote"> 14lbs</TD></TR></TABLE> is gonna yield over 400hp.
yes, you can run a 14b turbo at 30lbs and it will last a month or so, or a td05 at 35lbs and it will last a week. i was trying to be general while not being too much of an *** since he didnt understand my first comment.
i was just trying be low because the d series and h series stock sleeves are sh1tty and have problems with boost imo.
flipldls
Jun 12, 2010 08:25 AM
bb4 jdm lude
Jun 9, 2007 06:04 PM
DelSolMike
Aug 9, 2005 07:16 PM
KooK
Feb 5, 2004 01:42 PM
JDMCRX
Jul 16, 2003 11:08 AM
