How many rpms with built lsvtec
Hey ive searched the forum with no luck. Im wanting to know where to saftly stop spinning my new lsvtec turbo setup. Im looking for just over 400whp if possible any input from experince would help thanks.
Motor setup:
b16 head
holley 62mm tb
victor x manifold
gsr cams
crower springs and retainers
supertech stainless valves
81.5 je pistons
eagle h rods
gsr block with arp main,head, and rod studs
ls mircropolished and balanced crank
Turbo setup:
turbonetics t3/t4 57trim .63 ar turbo
ram horn manifold
tial 38mm wg
greddy type rs bov
cca intercooler
3 inch exhaust
Motor setup:
b16 head
holley 62mm tb
victor x manifold
gsr cams
81.5 je pistons
eagle h rods
Turbo setup:
ram horn manifold
tial 38mm wg
greddy type rs bov
cca intercooler
3 inch exhaust
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by koolaid3246 »</TD></TR><TR><TD CLASS="quote">
eagle h rods
= what can take the revs (looks like 9,000+ RPM)
b16 head
holley 62mm tb
victor x manifold
gsr cams
=Decides where the power will be ESPECIALLY the cams. Those cams on boost should start dropping torque around 8,400-9,000 RPM. This is variable because of many many many factors like amount of boost, manifold, TB, etc, etc, etc....every setup is different.
eagle h rods
b16 head
holley 62mm tb
victor x manifold
gsr cams
I rev mine to 9k. Revlimiter is 9100. I am going to change from GSR to CTR cams next month. Will see how the power picks up past 8k.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy »</TD></TR><TR><TD CLASS="quote">= what can take the revs (looks like 9,000+ RPM)
=Decides where the power will be ESPECIALLY the cams. Those cams on boost should start dropping torque around 8,400-9,000 RPM. This is variable because of many many many factors like amount of boost, manifold, TB, etc, etc, etc....every setup is different.</TD></TR></TABLE>
the gsr cams torque shouldnt start dropping at all at the power range he is looking for. he should be just perfect.
Samuels
Aug 11, 2006 06:39 PM
ExplicitSpeed
Mar 8, 2004 10:59 PM
