how many psi are your sohc motor pushing?
i was just wondering how many psi are you guys pushing on your sohc motor. also do you guys think a stock d16z6 will push 10 to 12 psi for a daily driven car?
OG triple OG
Re: (Pfieffdog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pfieffdog »</TD></TR><TR><TD CLASS="quote">Its all in the tune, what size turbo are you running, that is more important than psi so we can guesstimate whp.</TD></TR></TABLE>
ahah that is true ive been starting to get more and more into that . its not about psi its about horsepower numbers . if you boost 10 lbs on a 13b or a 13g , youll be ok . but if you boost 10 lbs on a t3 super 60 or somthing , once you actually hit full boost youll blow your motor in an instant , might be boosting above 300whp at 10 lbs wit that turbo
i wouldnt go above 200 whp just to be safe , it can be done and has been done many times , but you run the risk of breaking the motor.
Re: how many psi are your sohc motor pushing? (alpha_1)
depends on ur tune, how good of shape ur motor is in etc... My first setup, i blew the piston ringlands up after ~3months on the #4 piston. Still manage a 14.2 1/4 though on 3 cylinders oh yeah it was on about 9 psi.
Re: (Hella_JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM »</TD></TR><TR><TD CLASS="quote">
ahah that is true ive been starting to get more and more into that . its not about psi its about horsepower numbers . if you boost 10 lbs on a 13b or a 13g , youll be ok . but if you boost 10 lbs on a t3 super 60 or somthing , once you actually hit full boost youll blow your motor in an instant , might be boosting above 300whp at 10 lbs wit that turbo </TD></TR></TABLE>
So on a t3 super 60.. what psi would be safe?
Re: (Ape)
you can run more then 10psi on a good tune.
I ran 10psi daily creeping to 12psi on my bone stock d16z6 motor with 140k on it, and self tuned it since the only shop here rips people off and I never had a problem with it accept for irratic idle every once in a while.
OG triple OG
Re: (Ape)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ape »</TD></TR><TR><TD CLASS="quote">
So on a t3 super 60.. what psi would be safe?</TD></TR></TABLE>
i wouldnt be able to guess , youd have to get it on a dyno to see. start small.
Re: (Hella_JDM)
8psi everyday for over two years turn it up to 12psi now and then. Make 215whp on 12psi around 175whp on 8psi. Stock D16a6
Re: (Hella_JDM)
What are you talking about? 10 psi on a T3 super 60 making 300 whp? Yeah right give me a break. I had a SC50 which is a t3/t04E 50 trim pushing 10 psi all day and nothing ever blew up. I just ran the AFC hack tuned on a wideband for fuel management.
OG triple OG
Re: (Jkan2001)
depending on the trim of the turbo , a bigger turbo will take less boost to achieve the same amount of horsepower . a 50 trim is alot different than a 60 trim
Re: (Jkan2001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jkan2001 »</TD></TR><TR><TD CLASS="quote">What are you talking about? 10 psi on a T3 super 60 making 300 whp? Yeah right give me a break. I had a SC50 which is a t3/t04E 50 trim pushing 10 psi all day and nothing ever blew up. I just ran the AFC hack tuned on a wideband for fuel management.</TD></TR></TABLE>
ya what are u talking about? i ran 14psi on my y8 on a real turbonetics super60 (stock internals) until i blew the headgasket. i cant beleive thats all that blew. now im in the process of building that up. at 10 psi youll only be pushing about 200whp on a sohc. im currently boosting 10psi on a d15 with 200k on it. its all about the tuning.......
heres a lil some some for u guys.... that run was made at 12psi, dam elevations sucks *****.....http://www.d-seriesturboninja....?t=48
Modified by O.G.RENR at 10:39 AM 5/24/2004
Re: (Hella_JDM)
I push 10-11 psi (~.73 bar) on my d16z6 (stock) daily. It's been 20 k miles. It dyno'd right around 200whp... A friend is doing the same on a greddy turbo. They hold just fine.
Re: (Ape)
Wow!
This thread is giving me some motivation to complete my kit!
All I have left to buy is a blow off valve, charge pipes, and oil feed and return lines...
I can almost taste it!!
