how many degrees retarded
Old Nov 14, 2003 | 05:47 PM
cliff666's Avatar
Default how many degrees retarded
how many degrees should i retard my timing on my 95 b18b that is shooting a 75 shot zex????? i am running 2 steps colder of a plug and everything else is basically stock. should i retard it 2 or 4 degrees???thanks for any help
Old Nov 14, 2003 | 05:55 PM
turbonitrousgsr's Avatar
Default Re: how many degrees retarded (dragboy)
If it is a wet kit you should be safe taking about 2 degrees out, 4 if you want to be really safe. If it is a dry kit take out 4 deg for sure. Don't run anything less than 93 octane.
Old Nov 14, 2003 | 10:18 PM
cliff666's Avatar
Default Re: how many degrees retarded (alternativeGSR1)
with the spark plugs being 2 steps colder the car seems to idle alot higher. i havent shot it because i need the bottle filled now and i am adjusting my timing tom. big question is will the lag be noticable running it all motor when i am not juicing????? 4 degrees is alot
XzIpK
May 13, 2007 07:16 PM
Pullig
Apr 17, 2006 08:23 AM
NathanMorris
May 27, 2004 11:39 AM
sicklexus1
Jan 29, 2003 03:30 PM
grocerygetter
Aug 26, 2002 09:23 PM
