How long have you been boosted...problems?
Old Feb 21, 2006 | 06:52 AM
97CWITR's Avatar
Default How long have you been boosted...problems?
How long has everyone been boosted (miles) and what problems have they had with their setup?
Yes..each person drives differently, and does maintenance in different ways...
How long: miles
built bottom end or not:
Daily driver or not:
Problems so far:
Old Feb 21, 2006 | 07:15 AM
bluemax189's Avatar
Default Re: How long have you been boosted...problems? (96BLkGSR)
how long: 12,000 (turbo installed last summer)
Engine: d16y8
Built bottom end: not yet
Daily driver: of course, i cant afford another car
Problems: My heavy foot, other than that, nope
Old Feb 21, 2006 | 07:17 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
How long: 35,000 miles, 2.5 years
Built bottom end or not: Bone stock 146k mile D16Y8 bottom end, ARP headstuds & OEM HG 16k miles ago
Daily driver or not: Daily driver, only car I have, parked outside in -30 degree to 100+ degree weather, driven in snowstorms, thunderstorms, humid days, etc.
Problems so far: Other than a blown headgasket in '04, NOTHING!
Old Feb 21, 2006 | 07:43 AM
93supercoupe's Avatar
Default Re: How long have you been boosted...problems? (boostincoupe)
thats impressive
Make sure to include a power level and what size turbo.
Old Feb 21, 2006 | 07:46 AM
Default Re: How long have you been boosted...problems? (93supercoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe &raquo;</TD></TR><TR><TD CLASS="quote">thats impressive
Make sure to include a power level and what size turbo. </TD></TR></TABLE>
Pfft. It's only 183whp/163 tq. on a Greddy 15G at 7.5 psi.
w33k s0s
Old Feb 21, 2006 | 08:01 AM
bubs's Avatar
How long: ~12,000 miles
built bottom end or not: Stock H22A4
Daily driver or not: Daily Driven
Problems so far: Nothing related to the turbo install
Turbo/Power Level: BorgWarner .60/.70 T3/T04E @ ~5-6 psi, never dyno tuned, but I'm guessing 220whp.
Old Feb 21, 2006 | 08:32 AM
97CWITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe &raquo;</TD></TR><TR><TD CLASS="quote">How long: 35,000 miles, 2.5 years
Problems so far: Other than a blown headgasket in '04, NOTHING! </TD></TR></TABLE>
Old Feb 21, 2006 | 09:08 AM
BME1986's Avatar
About 10-12k with two 1000+ miles roadtrips
stock d16y7
Drove it everyday including winter
I had no problems with the car until the overboosted and hit 20psi.
Motor has since been rebuilt with forged internals.
Old Feb 21, 2006 | 10:19 AM
i2un's Avatar
98 integra JRSC'd.
How long: approx...91,000 boosted miles (around 7 years boosted).
built bottom end or not: stock
Daily driver or not: daily for approx 4 years, not my daily anymore (because of: traffic and a extreme clutch + thieves + a good deal on a daily beater).
Problems so far: Cracked the intake manifold once (replaced under Warranty). Burned the IAT sensor once, replaced the metal tensioners when the newer kits were upgraded. Replaced belts more times than I remeber....mostly out of maintenance, and replaced a loose bypass valve when the manifold was off.
No complaints, of a decision I made approx. 7 years ago. I've been wanting to switch to a monster turbo set-up for some years but if it ain't broke, and I am, why fix it.
Old Feb 21, 2006 | 10:28 AM
T3T495GSR's Avatar
Default Re: How long have you been boosted...problems? (Emiken)
Nice to see a solid running JRSC car on here
Old Feb 21, 2006 | 10:33 AM
i2un's Avatar
Default Re: How long have you been boosted...problems? (T3T495GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T3T495GSR &raquo;</TD></TR><TR><TD CLASS="quote">Nice to see a solid running JRSC car on here </TD></TR></TABLE>
Thanks
Old Feb 21, 2006 | 11:39 AM
rmcdaniels's Avatar
How long: 60,000 (about 3 years)
built bottom end or not: No, then yes, currently on 4th motor (Dart-block monster-motor)
Daily driver or not: yes
Problems so far: Blew up a couple of motors. One ran lean, busted all the pistons and ovaled out the stock sleeves, the other had a boost controller problem, ran 30+ PSI, got some preignition and melted the pistons. Lost about 6 head gaskets, destroyed a GT3071R turbo (all the bearings fell out and ran down into the oil pan). Destroyed the final drive set in the transmission. Many other minor things. It has run &gt;400 WHP with &gt;20 PSI of boost on my built B16, but am currently running a bit over 300 WHP with 8 PSI from a JRSC kit on a Dart-block motor.
Engine Management: AEM EMS (tuned by JDogg)
Modified by rmcdaniels at 10:51 PM 2/21/2006
Old Feb 21, 2006 | 12:05 PM
bigdaddyvtec's Avatar
* B A N N E D *
Default Re: How long have you been boosted...problems? (bluemax189)
F22 B1 (94 Accord EX). ALL STOCK block and head- Boosted it at 143,000 miles.
Boosted for about 2-3 months (3000 miles)- It is my daily driver. 265 WHP-273 TQ @ 10 psi (need a damn 2.5 bar MAP).
T3/04e 57 trim stage 3 wheel, .48/50 ar.
Tuned on Crome Pro.
Car runs like it came stock from the factory boosted..
Only problem so far is snapping the front motor mount in half (the steel motor bracket- no tourqe here-J/K) which in turn kinked my oil return line (smoke everywhere) thought I blew the damn motor, or burned up my snail, had to redo the return, and fab a new front mount out of a stocker, grinding it down, and gusseting the ****** with plate steel. feels much tighter now.
I do see axles in my future though...
Modified by bigdaddyvtec at 1:53 PM 2/21/2006
Old Feb 21, 2006 | 12:28 PM
LuderCriS's Avatar
Default Re: How long have you been boosted...problems? (bigdaddyvtec)
How long: boosted the car when it was 26xxx miles, now its 36xxx miles
Problems so far: none so far. my belt hasnt broken yet.
setup: jrsc 6psi
Old Feb 21, 2006 | 04:47 PM
97CWITR's Avatar
Default Re: How long have you been boosted...problems? (rmcdaniels)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote"> but am currently running a bit over 300 WHP with 8 PSI from a JRSC kit on a Dart-block motor.</TD></TR></TABLE>
impressive from a S/C!! only 8psi too
Old Feb 21, 2006 | 05:00 PM
rmcdaniels's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96BLkGSR &raquo;</TD></TR><TR><TD CLASS="quote">
impressive from a S/C!! only 8psi too</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1518026
Old Feb 21, 2006 | 05:01 PM
TurboInteg95's Avatar
30k miles
Stock B20 block
daily driver
260hp/224 ft/lbs
10psi, hondata, 550cc Inj. blah blah blah
Problems: Bolts kept coming loose on the damn downpipe, thats about it. That car currently is no longer boosted but is still running on the same motor.
Old Feb 21, 2006 | 05:32 PM
red11secondcivic's Avatar
How long: 5000mi
Built bottom end or not: stock lsvtec "junkyard motor"
Daily driver or not: weekend thrill ride
Problems so far: none at all, im running a t3t4 57 .63ar never been on the dyno but running 11.9 @116 with a 1.8 60" all done on a uberdata basemap @11psi
Old Feb 21, 2006 | 05:41 PM
TheShodan's Avatar
Moderator
about 6 years on a honda. about 60K on the first motor, and about 20K on the built one. Spun a bearing at idle due to failed oil pump. but otherwise, just fine.
Old Feb 21, 2006 | 06:11 PM
Jmunk's Avatar
Should post up what fuel management your running also.
Old Feb 21, 2006 | 06:42 PM
turboEGhatch's Avatar
How long: Just crossed 10K on this built motor, lasted 12K on the first build
built bottom end or not: GE sleeved LS/VTEC, manley rods, Arias pistons
Daily driver or not: Every Day
Problems so far: Runnin with just a mesh screen and no filter = I destroyed my turbo and did some damage to the pistons, bored it out from 81.5mm to 83mm and put a new turbo on it with a filter this time.
I just got back from a road trip where I had 3 other people in my car, two snowboards on the roof rack, and put 1000+ miles on it including some hard highway pulls with no issues
Old Feb 21, 2006 | 07:12 PM
turboteg2nv's Avatar
Default Re: How long have you been boosted...problems? (turboEGhatch)
How long: 8k miles
built bottom end or not: Stock B18b w/ 140k
Daily driver or not: Yes, daily.
Problems so far: Clutch started slipping (act stage1), fuel leans out at part throttle. (don't know what the problem is here..)
Old Feb 21, 2006 | 08:44 PM
turboteg55's Avatar
Default Re: How long have you been boosted...problems? (turboteg2nv)
How long: 16k miles
built bottom end or not: Forged pistons/Rods
Problems so far: No problems at all.. other than about 1,000k ago blew original headgasket. .. i guess it was time for a new one anyways.
Old Feb 21, 2006 | 08:58 PM
JDM00SI's Avatar
Default Re: How long have you been boosted...problems? (turboteg55)
i will keep this saved to my watched topics
Old Feb 21, 2006 | 09:02 PM
komat's Avatar
How long: 3000miles
built bottom end or not:stock b16a
Daily driver or not:dd
Problems so far:blew my motor at the dyno for a 280hp tune. damn weak ringlands
