fuel pump and fmu
Old Mar 17, 2002 | 08:24 PM
ludelvr's Avatar
Default fuel pump and fmu
I'm about ready to have my turbo put on, but I still need to have some things made up for me. I'm just wondering if I can install my FMU and fuel pump in the mean time. If so, what are the benefits or drawbacks if any in doing so? I just want to try and get some of the install stuff out of the way. Other questions I have are, will hooking up my fuel pump result in a higher fuel pressure or will it just allow more fuel to flow to the injectors and fuel filter? Also, where is the best place to hook up an inline fuel filter? I've heard in the back by the fuel tank, but in regards to the engine bay, before or after the fuel filter? Finally, does the FMU go before or after the stock fpr? Thanks guys
Old Mar 17, 2002 | 08:30 PM
1's Avatar
Default Re: fuel pump and fmu (ludelvr)
My turn.....
https://honda-tech.com/zerosearch
Old Mar 19, 2002 | 08:32 AM
ludelvr's Avatar
Default Re: fuel pump and fmu (1)
Okay, I did a few searches and wasn't able to find the info that I require. I just want to know if my fuel would be okay if I installed the fmu and the fuel pump on an NA motor for the mean time. thanks again.
Old Mar 19, 2002 | 08:46 AM
RGAZ's Avatar
New User
Answers:
1. The FMU won't affect NA car operation. Ok to install.
2. Fuel pump install may abnormally raise fuel pressure if the regulator cannot bypass enough fuel, but if it is a mid-range fuel pump it won't make a difference. Sorta Ok to install
3. Inline fuel filter should be close to the rail. But why? Are you replacing the stock one or using two?
4. FMU goes after the stock FPR.
You're welcome.
Randy
Old Mar 26, 2002 | 07:33 PM
ludelvr's Avatar
Default Re: fuel pump and fmu (RGAZ)
when installing the inline fuel pump, does it go before or after the fuel filter?
Old Mar 26, 2002 | 07:45 PM
Quaalude's Avatar
after...hard-lines go into the bottom of the stock fuel filter so it would be kinda hard to splice into
Old Mar 26, 2002 | 07:57 PM
SlowB16's Avatar
Doesnt the FMU go before the FPR. Dont you take the line going into the fpr off and plug it into the bottom of the FMU? Then a line from the side of the FMU into the stock FPR. And the top port goes to vacuum? Am I wrong?
Huee
Mar 12, 2004 10:01 PM
swpdb16
Apr 5, 2003 09:14 AM
ridnmyhonda
Feb 11, 2003 10:34 PM
v88dx
Feb 2, 2003 10:36 AM
revhrdls
Sep 9, 2001 10:29 PM
