how high should i go
Old Aug 19, 2002 | 01:46 PM
thejdmkid's Avatar
Default how high should i go
i have a fully built b18b ready to be boosted on, the cylinder head is fully built from reatainers to valves, i'm running dual web cam valve springs an custom cams.. the block was sleeved by darton an i'm running 8.5:1 arias pistons. an eagle rods...whats a good rev limit to set once everything is broken in.. i heard i can take it up to 10000rpm but i'm not sure how true that is...
Old Aug 19, 2002 | 04:02 PM
rjardy's Avatar
Default Re: how high should i go (thejdmkid)
that depends on when your setup stops making power...... hard to say really.
BTW still no luck on that ECU you wanted me to find,
Rob
Old Aug 20, 2002 | 02:08 PM
thejdmkid's Avatar
Default Re: how high should i go (rjardy)
oh so if i was using a t3/t40e it would stop making power before say a t60-1 but i would make it earlier?? i have a revhard stage 2 kit with the t3t40e i'm just wondering if that turbo is gonna be enough to make close to 400 whp.. or should i find a more efficent turbo???
89efhatchy
Apr 3, 2014 12:42 PM
89efhatchy
Mar 14, 2014 06:32 PM
civicegsick
Dec 30, 2007 11:54 PM
integranator
Jan 11, 2007 05:14 PM
Fatty_1775
Aug 9, 2006 07:42 PM
