How high do you rev your turbo car?
12 Years Strong
Getting ready to start boosting my B16, running an SC61 so I need all the RPMs I can get to make power. Keep in mind I will be upgrading my valvetrain. How high do most of you rev your boosted cars and still stay safe?
12 Years Strong
Re: How high do you rev your turbo car? (QCKGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QCKGSR »</TD></TR><TR><TD CLASS="quote">9000 is the pill in my msd.. </TD></TR></TABLE>
What bottom end are you using?
New User
Re: How high do you rev your turbo car? (HybridHatch88)
9k is the limiter set up on my Z-Dyne... She loves it.
SCREAMS around when passing traffic with the wastegate blaring.
GSR cams, balanced ITR valve springs from 2 full sets, the rest in the head is stock 1989 b16a.
12 Years Strong
Re: How high do you rev your turbo car? (B17aTrbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B17aTrbo »</TD></TR><TR><TD CLASS="quote">8500 but prolly still makes good power at 9k too!</TD></TR></TABLE>
Thats the good thing about a turbo car, no need for the cams to make power when the snail is making it
Re: How high do you rev your turbo car? (FOrSfEd)
the last stock block/head b16 we did w/sc61 we reved to 9800... it was still making power but we were skered cause the block was stock as ****.....
12 Years Strong
Re: How high do you rev your turbo car? (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg »</TD></TR><TR><TD CLASS="quote">the last stock block/head b16 we did w/sc61 we reved to 9800... it was still making power but we were skered cause the block was stock as ****..... </TD></TR></TABLE>
How much power did it make?
12 Years Strong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg »</TD></TR><TR><TD CLASS="quote">300hp.... 8psi on a pretty conservitive tune </TD></TR></TABLE>
DAMN! EMS tuned?
DAMN! EMS tuned?
Re: How high do you rev your turbo car? (Muckman)
i rev to 8000 rpms on my b18c1 with je pistons and eagle rods. i dont like going above 8000 rpms at 18-20 psi on stock valve train. until i get upgraded valve train i will stay at 8000 rpms unless i am wrong.... can i rev a lil higher on stock valve train and still be safe?
* B A N N E D *
Re: How high do you rev your turbo car? (NextelBuddy)
8500 at the most gotta remember the tranny is might grind anything higher
but for my up coming set up .. it will be b16 bottom end with gsr built head with a t3 .... might hav eit set to 9k
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridHatch88 »</TD></TR><TR><TD CLASS="quote">
DAMN! EMS tuned?</TD></TR></TABLE>
yep
yep
Re: How high do you rev your turbo car? (MiraiZ)
On my old setup i took it to 8500 new setup going to go to about 9.6-10 depending on how it looks on the dyno
Re: How high do you rev your turbo car? (99blackcivicSi)
i have a factory computer (p72) i just take it to the factory rev limit, my friend had a stock b16 in his 92-95 with a p30 and he ran it to the rev limit on it as well with after makert spings and what not i dont see why there would be any problems
R.P.M. = Ruins Peoples Motors
I'll be keeping it under 9K later(after I finish breaking in the engine) even though my head is built because of my stock Sleeves
whats safe for boosted h22 to to rev to? i take mine to 7500 but wonder if can go higher safely....that is...
12 Years Strong
Re: How high do you rev your turbo car? (dasher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dasher »</TD></TR><TR><TD CLASS="quote">R.P.M. = Ruins Peoples Motors
I'll be keeping it under 9K later(after I finish breaking in the engine) even though my head is built because of my stock Sleeves </TD></TR></TABLE>
Would it not be safe for my B16 to rev high with stock sleeves, perfect R/S ratio?
