How high can I rev?
Old Apr 21, 2003 | 12:44 PM
Scott - 93HB Si's Avatar
Default How high can I rev?
I'm building my trubo motor right now, and I've got some ITR valvesprings lying around.
If I put those in my B16A with B16A cams....how high can I safely set my rev limit? I know ITR is 8600 - but B16A cams have less lift, so can I rev higher than 8600?
Old Apr 21, 2003 | 12:53 PM
boosted hybrid's Avatar
Default Re: How high can I rev? (Scott - 93HB Si)
With the stock b16a cams you should be able to rev to around 9000 rpm safely. The ITR springs are plenty stiff for the lift of the b16a cams to 9,000 without valve float.
Old Apr 22, 2003 | 07:17 PM
1.8T_EG's Avatar
Default Re: How high can I rev? (boosted hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote">With the stock b16a cams you should be able to rev to around 9000 rpm safely. The ITR springs are plenty stiff for the lift of the b16a cams to 9,000 without valve float.</TD></TR></TABLE>
... (sorry to hijack thread)... but what about stock gsr head with itr intake springs (inner and outer) and the gsr intake springs moved to the exhaust side?... i have been told that i could rev up to 8500-9000 and you seem like a knowledgeable person to ask... lemme know... thanks...
F4i
Apr 16, 2008 01:53 PM
DC5ftmfw
10
May 23, 2007 12:33 PM
asilaydying1984
18
Nov 26, 2004 06:02 AM
CRXSiR2
Mar 14, 2004 04:47 PM
stramazzone
May 7, 2002 02:16 PM
