How high can i go???
I know this is a very bland and broad question....although i know alot of people on here have blown engines. How far do you think i can go with my setup, that is how many LBS???
Eagle H Beam Rods
JE 9.5:1 pistons
TDO5H-14B turbo
1G DSM IC
I'm running 8lbs right now (via the stock wastegate)
15 BTDC timing
AFC Hack(dsm intank fuel pump)
People say that by putting a MBC on your car it reduces spool time????
[Modified by BorderM3, 5:34 PM 1/13/2003]
Eagle H Beam Rods
JE 9.5:1 pistons
TDO5H-14B turbo
1G DSM IC
15 BTDC timing
you need
a bigger turbo
440cc+ injectors
boost controller
......and the sky is the limit. you may crack a sleeve! but just keep the a/f ratio good and listen for detonation and you will probably be good to about 1.4 bar(20.58psi). bu that is provided you get the propper tuning. ohh.....and you night want to drop you timming down to 14deg. it might help a little.
a bigger turbo
440cc+ injectors
boost controller
no one reccomends better fuel management????
i dont think 20psi can be had on the vafc hack
with the hack probably 10-11psi max...with better fuel mgmt you can prob go up to 18 depending on tuning
The stock Honda MAP is good for 9-10 psi depending on it's era. At 8 psi, there's a good chance he'll crack piston lands with the cracked out AFC hacked timing.
Have you seen the Secrets Part 4 thread? Both filetofit and myself posted up some good information on this subject.
I did recomend a few fuel ststem upgrades. and why can't he use a vafc hack? my car has seen 1.4 bar and runs 14psi daily with a safc. belive me it can be done very esily as long as you are knowledgabe about your afc and have a a/f gauge you can trust. if you dont want to spend tons of cash on a satndalone, it can be done witout one. granted there are limitations but there are some damb fast cars with a safc!
he WONT crack aftermarket rings with 10 PSI.
Rob
since when did a fuel computer have anything to do with ignition timing?
Rob
Rob
