How the hell do you take off the rotor inside the dist cap?
Old May 4, 2002 | 05:57 PM
b18tdelsol's Avatar
Default How the hell do you take off the rotor inside the dist cap?
Im trying to install the msd cap convertor,. so it has a external coil..but ****.. i cant seem tto take the rotor off, i dont wanna break it..can some help me?
Old May 4, 2002 | 06:00 PM
falcongsr's Avatar
What is this crap?
Default Re: How the hell do you take off the rotor inside the dist cap? (b18tdelsol)
isint there a screw holding it in? i think its easier to get to if u remove the distributor (5 min)
Old May 4, 2002 | 06:10 PM
immortal's Avatar
Banned
Default Re: How the hell do you take off the rotor inside the dist cap? (falconGSR)
the screw is in there TIGHT
and make sure when you put it back on you TIGHTEN THAT BITCH HARD
i was racing a supercharged s2k on the freeway and my ignition rotor broke off
Old May 4, 2002 | 06:11 PM
falcongsr's Avatar
What is this crap?
Default Re: How the hell do you take off the rotor inside the dist cap? (immortal)
ugh. i might go check mine
Old May 4, 2002 | 07:57 PM
blkDOHCsol's Avatar
New User
you may have to either roll the car forward, so the button turns, otherwise you cant get at the screw.
Old May 4, 2002 | 08:08 PM
Ri5e's Avatar
Default Re: How the hell do you take off the rotor inside the dist cap? (blkDOHCsol)
crank the car so that the rotor turns, and the 1 screw is exposed. then u can unscrew it off
Old May 4, 2002 | 08:13 PM
b18tdelsol's Avatar
Default Re: How the hell do you take off the rotor inside the dist cap? (BG Boost)
thanks guys i got it off.. now.. do any of you have a crane ignition? do u know where the red and the white wire goes? i got everything else, im just not sure if it connects to the wires that used to connect the old coil...?
Old May 4, 2002 | 10:12 PM
sushibug's Avatar
i was really lucky when i took mine out, it was in a perfect spot to get to. took me ten seconds to get it out, took my friend two hours.
Old May 4, 2002 | 10:18 PM
ninesecrx's Avatar
Default Re: How the hell do you take off the rotor inside the dist cap? (sushibug)
[Modified by ninesecrx, 10:10 AM 5/5/2002]
janek
Mar 14, 2013 06:09 PM
paniaguae640
Nov 27, 2007 03:57 PM
Utilitarian
Jul 14, 2003 04:53 AM
bocian
Feb 20, 2002 06:50 PM
