How hard is it?
Old Jan 17, 2003 | 04:16 PM
Specialk's Avatar
Default How hard is it?
how hard is it to rebuild a turbo with a rebuild kit? and one other question, would a t3 with .63 turbine and .60 compressor be good for about 10-12 psi on an LS integra. thanks.
[Modified by Specialk, 1:16 AM 1/18/2003]
Old Jan 17, 2003 | 04:25 PM
Joseph Davis's Avatar
Default Re: How hard is it? (Specialk)
Rebuilding a turbo is the simplest thing you'll ever do, but can be near impossible. <g>
Turbos held together with V-band clamps, like the Mitsu units, are very easy. Garrett T-series are huge PITA if they haven't been apart in a while... You'll use a couple gallons of penetrating lube and a torch trying to get the rust bolts off.
Check www.dsm.org to walk you through rebuilds. One of the Grand National sites (GN.org or some such) has good Garrett-specific rebuild info. Making sure you have the wheels in proper alignment with the shaft, and whether the parts were balanced seperately or as a unit dictates whether or not you have to have the turbo balanced afterward.
I got my last three T3 rebuild kits from TEC (Turbo Engineering Co) in Golden, Colorado. Expect to pay $58 including shipping, and prompt service.
A .60 trim T3 flows enough for 300 hp, so yes it's a good match for an LS at the typical 10-12 psi power levels.
Old Jan 18, 2003 | 12:13 PM
Specialk's Avatar
Default Re: How hard is it? (J. Davis)
thank you. 1 more question, so would 200bux be a decent price for a turbo and rebuild kit, same turbo i think he said it was off an old t-bird. thanks again.
Old Jan 18, 2003 | 08:44 PM
I could do better with buying a used smoking POS turbo that hadn't had the wheels hit the housings yet, and swap wategate actuator + housings onto a $125 reman CHRA.
dcmatt
Dec 13, 2010 10:37 PM
japspecb7
Apr 16, 2008 04:54 PM
racinskittle
Jun 28, 2003 03:19 PM
Full-Race Geoff
Aug 31, 2002 08:19 AM
