How does the vortech fmu actually work?
Old Jul 21, 2002 | 11:42 AM
Integra_Boi's Avatar
New User
Default How does the vortech fmu actually work?
i know the fuel goes in and there is a out and there is a vacuum source.. but what does it do to up the pressure..?
Old Jul 21, 2002 | 12:49 PM
niedejb's Avatar
Default Re: How does the vortech fmu actually work? (Integra_Boi)
The boost presses on a rubber diaphragm. The diaphragm pushes on the calibration disk (the bigger the disk the bigger the push). The disk rides on a metal plunger that begins to close off flow through the unit as its pushed down.
At vacuum the diaphragm is lifted off the disk and plunger allowing all the flow through. At boost the pressure on the diaphragm restricts the flow through based on how big the disk is.
Old Aug 10, 2002 | 05:53 AM
Hybrid's Avatar
Default Re: How does the vortech fmu actually work? (niedejb)
To continue this archived topic a little....................
So when you open the FMU the metal plunger is not spring loaded, thus don't freely move with the fmu apart?
BoostedD15B7
Nov 11, 2002 11:41 AM
HybridKOOP
Aug 4, 2002 04:20 AM
b18tdelsol
May 10, 2002 11:28 AM
boosted3g
Oct 1, 2001 01:09 PM
