How does this happen? blown gasket
Old 10-02-2005, 01:20 PM
planeman01's Avatar
Default How does this happen? blown gasket
Check this out...how does this happen?! This is on a boosted 3rd gen prelude.
Straight t3, walbro, dsm injectors, tial wg, FMIC, 2.5 inch dp/exhaust, tuned on crome 6psi
Thoughts?
TIA
Rick
Old 10-02-2005, 01:42 PM
non-VTEC's Avatar
Default Re: How does this happen? blown gasket (planeman01)
thats a shitty gasket to begin with.
get the OEM 3-layer stainless metal gasket or mr. gasket has a nice copper exhaust manifold gasket that works really well especially if your manifold flange is warped.
Old 10-02-2005, 01:49 PM
planeman01's Avatar
ummm... it was a OEM gasket to begin with
Old 10-02-2005, 02:13 PM
extremepowerperformance's Avatar
Default Re: How does this happen? blown gasket (non-VTEC)
I agree. That is a shitty gasket. Time to upgrade!
Gabriel
Old 10-02-2005, 02:21 PM
planeman01's Avatar
its oem...i've never considered Honda Original Parts as ****...It was brand new when i put it in
Old 10-02-2005, 02:33 PM
onlinehost's Avatar
thats not an oem honda gasket oem is 3 layer metal
Old 10-02-2005, 02:38 PM
non-VTEC's Avatar
Default Re: (planeman01)
hmmm.......it doesn't look like a honda gasket.........but i never had a 3'rd gen lude apart before so i guess it could be.
just get a new gasket.....make sure the manifold flange is clean. and make sure its not to badly warped. and try torquing the nuts down evenly....
I'm using a copper exhaust manifold gasket made by mr. gasket that works great.....had it for 4-5 years and reused it over and over again. it never leaks.
Old 10-02-2005, 02:42 PM
planeman01's Avatar
i replaced it with a new one from honda, we'll see what happens i guess...
i don't get how it tore the holes for the studs, and moved to block the port like it did...see how its all black? It moved under the friking manifold...a leak i could see but the whole thing moving like it did?
Rick
Old 10-02-2005, 02:47 PM
non-VTEC's Avatar
sounds like maybe the nuts may have worked themselves loose over time causing the gastet to move/distroy itself.....
try some lockwashers if you can fit them?
Old 10-02-2005, 03:09 PM
EBP.EM1's Avatar
could the head flange be alil bit warped?
Old 10-02-2005, 03:49 PM
planeman01's Avatar
i think the flange might be warped a touch
Old 10-02-2005, 03:51 PM
project dc2's Avatar
warped flange/ cheap gasket. get a copper or oem gasket as said b4.
COPPER
Old 10-02-2005, 03:53 PM
B20luda's Avatar
Default Re: (1slow4dr)
the older preludes use the shitty gaskets they dont use the metal ones..that goes for the head gasket also...but i havent had any problems..
Old 10-02-2005, 04:08 PM
22psicrx's Avatar
Default Re: (B20luda)
Maybe the bolts are stripped or studs. When you tightened down the manifold maybe you tightened them to tight.
Old 10-02-2005, 05:48 PM
D-t
D-t's Avatar
Default Re: (non-VTEC)
Have a link for that gasket?
Old 10-02-2005, 05:55 PM
USDM 4G VTEC's Avatar
i dont know about others
but that picture right there shows the gasket inproperly installed
how the **** are the ports marked on the gasket with black stuff when is properly installed
u can even tell, they made new holes to make it fit
i bet ya thats a B series or D series gasket
go home boy and buy a real gasket and the right onw from the engine
stop posting stuff like this and take our time when it was not done right to begin with
Old 10-02-2005, 06:09 PM
N20civicB18's Avatar
Default Re: (USDM 4G VTEC)
ha
Old 10-02-2005, 06:24 PM
simike's Avatar
Default Re: (N20civicB18)
The gasket was installed wrong. It only fits one way. Should be very obvious when installing it.
Old 10-02-2005, 06:34 PM
oscarmayer's Avatar
that was either incorrectly installed, or the gasket was just a gasket incorrectly makked and the honda dealer didn;t catch it when they gave it to you.
either way, before you install the manifold back, check the holes and ensure the gasket isn;t covering the th hols up. if it covers that much still, something is wrong with the gasket, or your getting parts for the wrong motor.
Old 10-02-2005, 07:58 PM
mike93eh
Guest
Posts: n/a
installed wrong. and you should be using a metal gasket anyways.....mr gasket
Old 10-02-2005, 08:06 PM
GWInquisitor14's Avatar
Default Re: (mike93eh)
thats is for sure not a stock gasket, did u use the locking bolts? if they came loose, that would definatly mess it up. Happened to my wastegate gasket, looked the exact same way.
Old 10-02-2005, 09:34 PM
AspectIndustries's Avatar
Default Re: (GWInquisitor14)
Lol. Ghettofabulous Owns ya
Old 10-02-2005, 10:04 PM
planeman01's Avatar
ok dudes-
i did not use a gasket for another motor
i did not make new holes to make it fit
it is an OEM BRAND NEW GASKET
it fit perfectly when i put it on. the pressure or somthing made it move and tear like that.
I'd run a copper one if they were availible for the b20A (A! not b or z) this is a 90 PRELUDE!
I'm not a hack trying to half *** here
Old 10-03-2005, 05:25 AM
Tactic$'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
Im glad someone finally picked up on that one.
Old 10-03-2005, 07:55 AM
khoalie's Avatar
Default Re: (Tactic$)
would a metal one from an ls fit?
Quick Reply: How does this happen? blown gasket
