How do you tune for detonation you cannot hear?
Old Jun 16, 2003 | 07:47 PM
IloveNewt's Avatar
Default How do you tune for detonation you cannot hear?
I was wondering when you tune a built engine meanign forged pistons w/sleeved block, where the knock sensor may be dissabled, how does oen tune for detonation that is not audible?
I have heard that although it may not be audible, it could still cause damage. Do u guys just use the factory knock sensor after the engine is all warmed up?
Old Jun 16, 2003 | 08:07 PM
rioninja's Avatar
Default Re: How do you tune for detonation you cannot hear? (MordecaiPSI)
stethoscope
Old Jun 16, 2003 | 08:35 PM
IloveNewt's Avatar
Default Re: How do you tune for detonation you cannot hear? (rioninja)
Really? (u kiddin or r u serious)
Just use a stethoscope right up on a flat surface on the block?
Old Jun 16, 2003 | 08:39 PM
Muckman's Avatar
Moderator in Chief
why cant you use the knock sensor on a built motor?
Old Jun 16, 2003 | 09:02 PM
IloveNewt's Avatar
Default Re: How do you tune for detonation you cannot hear? (Muckman)
Well im not sure if my p75 ecu is able to read my knock sensor, it might. Also it might read false knock cause of piston slap, but that might not be a prob if the engine is warmed up.
How does the stock knock sensor do in sensing knock?
Old Jun 16, 2003 | 10:11 PM
sporkcrx's Avatar
Wouldn't the forged pistons have a little more slap/noise than the stock? Freaking out the stock sensor? I'm interested too (because I don't have a knock sensor )
Old Jun 16, 2003 | 11:37 PM
IloveNewt's Avatar
Default Re: How do you tune for detonation you cannot hear? (sporkcrx)
what do the hondata gurus do?
Old Jun 17, 2003 | 12:12 AM
SuperSH's Avatar
Consider a J&S Safeguard for knock detection.(I know its expensive) It only listens for knock when the corrisponding piston gets within a certan Deg. of TDC. In other words it only listens for knock when its supposed to happen, and not all the time. Another listening device is here>> http://www.autospeed.com/cms/article.html?&A=0348 Its basicly a low wattage amplifier attached to a microphone. Just some suggestions.
Old Jun 17, 2003 | 01:03 AM
lazerus's Avatar
Default Re: How do you tune for detonation you cannot hear? (SuperSH)
i use a 15 dollar unit i make that has a clip that you attach to a bolt near the top of the block... works great for me :-)
Old Jun 17, 2003 | 01:06 AM
SiRkid's Avatar
j&s is too sensitive...well for built motors it is.
too much other noise which would set it off
Old Jun 17, 2003 | 02:12 AM
dirtySOHC's's Avatar
Default Re: How do you tune for detonation you cannot hear? (lazerus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazerus &raquo;</TD></TR><TR><TD CLASS="quote">i use a 15 dollar unit i make that has a clip that you attach to a bolt near the top of the block... works great for me :-)</TD></TR></TABLE>
can you tell me what this is and has it saved you when you are boosting? i need something like this......
Old Jun 18, 2003 | 11:15 PM
SuperSH's Avatar
Default Re: How do you tune for detonation you cannot hear? (SiRkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRkid &raquo;</TD></TR><TR><TD CLASS="quote">j&s is too sensitive...well for built motors it is.
too much other noise which would set it off</TD></TR></TABLE>
You can adjust the sensitivity of the unit so it won't detect the slap but they are a pricey option. Also in decreasing the sensitivy it would have a hard time detecting actual knock.
Old Jun 19, 2003 | 02:11 AM
qwkteg125's Avatar
how about checking the plugs after a run?
Old Jun 19, 2003 | 02:20 AM
lazerus's Avatar
Default Re: How do you tune for detonation you cannot hear? (dirtySOHC's)
it's basically a modified hearing amplifier from radio shack.
it works extremely well for tuning purposes... because any human is better than an electronic device as far as hearing goes. so you can be the judge if you are detonating or not...
i'll get some part numbers and post them here for you guys... it costs about 15-20 bucks total, and all you need is a soldering iron a small screwdriver, and electrical tape....
Brad
Old Jun 19, 2003 | 10:23 AM
psileepR's Avatar
New User
a write up would be great... keep us updated
Old Jun 19, 2003 | 10:46 AM
sporkcrx's Avatar
Default Re: How do you tune for detonation you cannot hear? (Civtek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civtek &raquo;</TD></TR><TR><TD CLASS="quote">a write up would be great... keep us updated </TD></TR></TABLE>
Old Jun 19, 2003 | 10:57 AM
mos's Avatar
mos
I need this device.
Old Jun 19, 2003 | 11:05 AM
int3gra's Avatar
Default Re: How do you tune for detonation you cannot hear? (mos)
me 2
Old Jun 19, 2003 | 11:55 AM
Muad'Dib's Avatar
Corr Performance Pilot
Well the way that I see/listen for detonation is with the help of my J&S Meter and also my EMS. You can get an audible sensor for the J&S as well.
Old Jun 19, 2003 | 12:24 PM
servion's Avatar
Yes... please keep us informed
TopEndTuner
Engine Management and Tuning
Mar 7, 2010 08:31 PM
rice is nice
Feb 23, 2009 08:21 AM
rice is nice
Apr 14, 2005 08:46 PM
qwklude82
Jan 13, 2003 06:00 PM
delslow94
Dec 26, 2002 12:52 PM
