how to do you know when to bore a block?
i just got a stock LS block and it has some scratches inside one of the cylinders.
if i run my finger nail on it i could feel it if as i go around the cylinder. its like a
little dip.
Can honing cure it? or does it need to be Bored?
little dip.
IF you rub your finger around the cylinders and yer finger feels any marks, if your fingernail stops on the mark, then bore it, if its just a light light scratch, then hone it, then try the finger test again...should help
if the scratch is big enough to stop your fingernail definitely bore it. or if its a bunch of little scratches you might get away with honing it.
guy_from_nerk
Jul 28, 2013 12:25 PM
