How do you get this head off???
Old Jan 28, 2004 | 08:35 PM
Rod.'s Avatar
Default How do you get this head off???
how do you get the cams out so I can take the head off? What all do I have to do
Old Jan 28, 2004 | 08:37 PM
grndcont's Avatar
once the bolts are out, just pull (carefully). there might be some honda-bond holding them on. try and wiggle the capps.
Old Jan 28, 2004 | 08:38 PM
R THIS's Avatar
Default Re: How do you get this head off??? (redturbocivic)
those have dowel pins in them.... i took min of by gently wiggling them.. do not force them, or hammer them......
Old Jan 28, 2004 | 08:43 PM
Rod.'s Avatar
Default Re: How do you get this head off??? (R THIS)
I just wiggled those things, seem like their on by cement. There has to be a way to get those off.
Old Jan 28, 2004 | 08:46 PM
thaiphob's Avatar
Nikon!!!
i say using a blunt non sharp object to lift em up.
Old Jan 28, 2004 | 08:49 PM
Mr. Softee's Avatar
Default Re: How do you get this head off??? (thaiphob)
usually they pop up if you rotate the cam gear
Old Jan 28, 2004 | 08:52 PM
tilt's Avatar
i rotate the camgears a bit and it pops up.
Old Jan 28, 2004 | 08:54 PM
MikeMAN's Avatar
Default Re: How do you get this head off??? (tilt)
wiggle wiggle
mike
Old Jan 28, 2004 | 09:07 PM
tegsol1's Avatar
plastic hammer will do the job
Old Jan 28, 2004 | 09:11 PM
lazerus's Avatar
Default Re: How do you get this head off??? (tegsol1)
you can slide a bolt 1/2 way back through the cam cap and put a side to side motion on it. keep working with them and they will come off.
Old Jan 28, 2004 | 09:17 PM
TravSi's Avatar
Default Re: How do you get this head off??? (lazerus)
rubber mallet and wiggle
Old Jan 28, 2004 | 09:19 PM
Rod.'s Avatar
Default Re: How do you get this head off??? (TravSi)
when i get those off, what all is left? The big bolts that go along the bottom of the head?
InfamousRS's Avatar
you just have to tap them back and forth with a mallet a few times...the dowel pins hold them in there pretty good.
Old Jan 28, 2004 | 09:50 PM
boostedcvc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazerus &raquo;</TD></TR><TR><TD CLASS="quote">you can slide a bolt 1/2 way back through the cam cap and put a side to side motion on it. keep working with them and they will come off.</TD></TR></TABLE>
This has worked for me multiple times!
Old Jan 28, 2004 | 10:00 PM
Foozball26's Avatar
Default Re: How do you get this head off??? (boostedcvc)
i have a screwdriver that fits in the hole and i just wiggle it back and forth and use a tiny prybar for the other side.
Old Jan 28, 2004 | 10:10 PM
99blackcivicSi's Avatar
Default Re: How do you get this head off??? (Foozball26)
rubber mallet or wiggeling, then you take the cams out (don't forget to set everything to TDC) and then undo the had bolts and then lift the head off/.
Old Jan 28, 2004 | 10:13 PM
XSIintegra's Avatar
The rubber mallet works good. Make sure you don't try to pry up a cam....A friend of mine got a little bit frustated and did that and cracked a good gsr cam.
Old Jan 28, 2004 | 10:15 PM
Adi Radoncic's Avatar
On Fire!
don't use a jack hammer.
Old Jan 28, 2004 | 10:48 PM
Rod.'s Avatar
Default Re: How do you get this head off??? (newgsr)
thanks guys, I got them off. Now I am to the headstuds. I just broke one of my fu*kin extensions in my socket . No breaker bar here...
Rating 1-10. How hard is it to assembly a bottom end? What is the difficult part?
Old Jan 28, 2004 | 11:42 PM
boosted_dc2's Avatar
dude no offense but if you had that much trouble getting the caps off, then dont try a bottom end. i can get a head off in no time but i wont touch a bottom end.....i guell i dont have the confidence yet.
Landon
Old Jan 28, 2004 | 11:49 PM
lazerus's Avatar
Default Re: How do you get this head off??? (boosted_dc2)
it's all very easy to dissasemble, its assembly thats the harder part. (which isn't that hard if you are read about it and have confidence in yourself.
difficulty is probably a 8.
If you dont know what you are doing, you will fail.
Old Jan 29, 2004 | 12:55 AM
Hoosier Daddy's Avatar
Default Re: How do you get this head off??? (jz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jz &raquo;</TD></TR><TR><TD CLASS="quote">try hitting the ends with a rubber mallet. </TD></TR></TABLE>
Old Jan 29, 2004 | 05:30 AM
Ri5e's Avatar
Default Re: How do you get this head off??? (Hoosier Daddy)
Like everyone else says, wiggle wiggle
That's why you should get a VTEC head ...
Old Jan 29, 2004 | 08:50 AM
Rod.'s Avatar
Default Re: How do you get this head off??? (BG Boost)
I want a vtec head...I am searching
Old Jan 29, 2004 | 08:58 AM
psileepR's Avatar
New User
Thats what i do
