How do you clear check engine light???
Old Aug 18, 2003 | 06:20 PM
92TEGsrSC's Avatar
Default How do you clear check engine light???
I just finished installing a JRSC on a 94 GSR... the check engine light came on because i hadn't reinstalled the O2 sensor on the cat... I know this is the problem because it blinked a 41 code which is the one for the 02 sensor... anyway, I plugged the sensor back in... how do I make the light go away????
Thanks in Advance,
Zack
Old Aug 18, 2003 | 07:05 PM
RIX982DRLS's Avatar
Default Re: How do you clear check engine light??? (92TEGsrSC)
on my 98 ls when your sitting in the driver seat look at your car key, right about that point right under your dash about 10mm's back there is a button. turn your key so that the radio is on but don't start the car, hold the button down for about 10 seconds and the light will go off.
Old Aug 18, 2003 | 07:14 PM
pip9's Avatar
Default Re: How do you clear check engine light??? (RIX982DRLS)
disconnect the neg terminal of ur battery for like 10 secs.
doitmyself2010
May 24, 2010 12:58 PM
Bango_Vang01
Jan 19, 2010 03:02 PM
HondaPH22
Jul 14, 2006 12:06 PM
Groove_D
Jan 4, 2005 01:13 PM
GRAVEDIGGER
Oct 8, 2002 01:12 AM
