How do set up this wastegate?
Old Mar 9, 2006 | 05:52 AM
thugnutts's Avatar
Default How do set up this wastegate?
I have a t3 turbo with a integrated wastegate and i dont know how to set it up. There are two holes on the wastegate and both holes boost more that ten lbs. My question is if one of those hole goes to a vac. line on the manifold?
Old Mar 9, 2006 | 07:05 AM
TIGboy's Avatar
Default Re: How do set up this wastegate? (thugnutts)
what do you mean by holes? nipples you mean? and what do you mean by both holes boost more than 10lbs?
Old Mar 9, 2006 | 10:45 AM
skratchnsnift's Avatar
the hole on the top is for the boost controller. the one on the side is for vacuum.
Old Mar 9, 2006 | 11:49 AM
StolenTeg's Avatar
Default Re: (skratchnsnift)
I thought internal wastegate only have one hole for vacuum, only external have 2 hole
Old Mar 9, 2006 | 09:03 PM
thugnutts's Avatar
Default Re: How do set up this wastegate? (SMS-Fabricator)
yes it has two nipples and what mean by more than ten lbs. is that when i boost it does not stop boosting. One of those nipples is plug into the turbo. Where does the other one go?
98integralsB18
Jul 25, 2009 07:29 AM
DaYZeD.1
Mar 28, 2008 06:54 AM
rbf351
Dec 17, 2002 06:10 AM
blu_si
Oct 1, 2002 04:20 PM
_Endless_
Sep 23, 2002 10:00 PM
