how do my compression numbers look
Old May 22, 2004 | 09:27 AM
FOrSfEd's Avatar
Default how do my compression numbers look
Since my car started smoking a lil bit when the car warms up and I drive I decide to see what could be the problem. When it smokes the smoke is blue.
So I did a test here are the numbers
250
250
250
250
So I guess if these look right then it must be my seals in my turbo. Any thoughts
Motor is a stock b18c5
Modified by FOrSfEd at 8:51 PM 5/23/2004
Old May 22, 2004 | 09:39 AM
lkshs123's Avatar
Default Re: how do my compression numbers look (FOrSfEd)
good numbers
Old May 22, 2004 | 10:17 AM
FOrSfEd's Avatar
Default Re: how do my compression numbers look (lkshs123)
up
Old May 22, 2004 | 10:27 AM
B18C1CYA's Avatar
try a leak down test it might show you some thing diffrent, i did a comp test on my buddy car and it was ok, but the leak down showd 65% in #4 and he was burning oil pritty bad, but the test only takes like 15mins and is a good pice of mind and can tell you alot about whats going on in the motor
Old May 22, 2004 | 11:16 AM
turbotypeR@SPEC's Avatar
25 Year Member
the smoke is probably coming from the oil drain.mine smoked during warm-up until i moved the oil drain to the block.try running a lower oil level.the problem is that if you have your drain in the pan,the oil level is usually to high.
Old May 22, 2004 | 11:27 AM
FOrSfEd's Avatar
Default Re: how do my compression numbers look (turbotypeR)
Not sure if I'm following what you are saying Danny.
Old May 22, 2004 | 12:24 PM
FOrSfEd's Avatar
ttt
Old May 22, 2004 | 12:46 PM
boosted_dc2's Avatar
yea those numbers are good, blue smoke is usually oil return/turbo related as stated above. aslo im not sure but i think a crappy pcv system can cause some blue smoke as well.
Landon
Old May 22, 2004 | 02:31 PM
FOrSfEd's Avatar
Default Re: how do my compression numbers look (boosted_dc2)
thanks for the help everyone.. Anymore
Old May 22, 2004 | 02:54 PM
boostedbastard's Avatar
Those numbers seem a tad bit low to me. How much boost you running on it? I could be like the previous guy said about the pcv on the smoke but your copression rings could be a little weak also. May wanna do a leak down test just to be sure. A C5 is an expensive thing to replace if you take it too far.
Old May 22, 2004 | 03:31 PM
sway892's Avatar
whats ttt?
Old May 22, 2004 | 03:38 PM
rusteds2k's Avatar
Default Re: how do my compression numbers look (lexvdub1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lexvdub1 &raquo;</TD></TR><TR><TD CLASS="quote">whats ttt? </TD></TR></TABLE>
To The Top
Old May 23, 2004 | 07:34 PM
25 Year Member
Old May 23, 2004 | 08:20 PM
dunkd's Avatar
wow ive never seen an oil return going to the block...
Old May 23, 2004 | 08:27 PM
Muckman's Avatar
Moderator in Chief
Will a compression or leakdown test actually test the oil ring? The top two rings hold back the compression and Ive been told the oil ring can have problems but not show up on a leakdown or compression test.
Old May 24, 2004 | 04:22 AM
FOrSfEd's Avatar
up
Old May 24, 2004 | 05:21 AM
imurdaddy's Avatar
yeah those numbers looks pretty up there
Old May 24, 2004 | 05:25 AM
FOrSfEd's Avatar
Default Re: how do my compression numbers look (imurdaddy)
I would like totap my oil drain into the block just scared about messing something up.
Old May 24, 2004 | 05:32 AM
RobbieG35's Avatar
12 Years Strong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOrSfEd &raquo;</TD></TR><TR><TD CLASS="quote">I would like totap my oil drain into the block just scared about messing something up.</TD></TR></TABLE>
What is the advantage of doing this rather than just tapping the oil pan?
Old May 24, 2004 | 08:10 AM
RyanEJ8's Avatar
Default Re: how do my compression numbers look (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Will a compression or leakdown test actually test the oil ring? The top two rings hold back the compression and Ive been told the oil ring can have problems but not show up on a leakdown or compression test.</TD></TR></TABLE>
It is very possible that a compression test wouldn't show oil ring wear or damage.
Old May 24, 2004 | 08:47 AM
FOrSfEd's Avatar
Default Re: how do my compression numbers look (HybridHatch88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridHatch88 &raquo;</TD></TR><TR><TD CLASS="quote">
What is the advantage of doing this rather than just tapping the oil pan?</TD></TR></TABLE>
The oil level would never be high enough to drain back into your turbo if your line is up there on the block. I think it is a great idea I'm just kinda hesitant.
Old May 24, 2004 | 08:54 AM
RobbieG35's Avatar
12 Years Strong
The oil level would never be high enough to drain back into your turbo if your line is up there on the block. I think it is a great idea I'm just kinda hesitant.</TD></TR></TABLE>
O okay, seems like a good idea, but tapping the block would make me nervous
Old May 24, 2004 | 09:23 AM
Muckman's Avatar
Moderator in Chief
Default Re: how do my compression numbers look (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">
It is very possible that a compression test wouldn't show oil ring wear or damage.</TD></TR></TABLE>
My beater is a 91 LS and it burns oil like its a 2 stroke. No doubt its the rings as the head is new. Compression test are 190 +/- 2 in each cylinder. Leakdown is less than 5% loss.
Old Jun 1, 2004 | 07:38 AM
seen4ever's Avatar
could get a moroso oil pan, baffled and has a high mount spot for the oil return line. They are a little expensive, but to tap into the block would require it being out of the car with it broken down, so cheaper than that.
Old Jun 1, 2004 | 09:02 AM
Type-ARR's Avatar
Default Re: how do my compression numbers look (seen4ever)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seen4ever &raquo;</TD></TR><TR><TD CLASS="quote">could get a moroso oil pan, baffled and has a high mount spot for the oil return line. They are a little expensive, but to tap into the block would require it being out of the car with it broken down, so cheaper than that.</TD></TR></TABLE>
If you get that oil pan you will have to put less oil in your car for it to be filled, a few people on this board killed the seals on there turbos by having that pan and filling it above the return. . .
98exowner
Sep 9, 2008 12:15 PM
acman1
Apr 26, 2007 11:19 AM
Fat Chick Magnet
Nov 24, 2006 02:50 PM
Fat Chick Magnet
Nov 22, 2006 09:52 PM
CRX SiR T
Nov 24, 2003 12:49 PM
