how do i get to the tune shop?
Old Feb 23, 2006 | 02:50 PM
LoseRPunKx182's Avatar
Default how do i get to the tune shop?
i didn't think of this till today but how do i get to the tune shop after installing my turbo kit? i know phearable.net can make me a basemap but how safe is it?
also i was wondering if i could use this elbow and re-route the wg? here's my manifold so you get the idea. if i dont re-route it, the wg will probably not clear the rad and i'm tryin to keep a full rad.
how's my list look?
here's what i have so far:
shorty tub manifold
t3/t4 .48/.60 50trim
38mm tial 10psi
greddy type-s
dsm 450 blacktops
boost & oil pressure gauge
aem fpr
apexi turbo timer
chipped p72
what i need:
downpipe
intercooler
ic piping
spark plugs
fuel pump
oil lines
coolant lines
aimming for 300whp
Modified by LoseRPunKx182 at 8:27 PM 2/23/2006
Old Feb 23, 2006 | 03:00 PM
EK FLY's Avatar
Default Re: how do i get to the tune shop? (LoseRPunKx182)
probably some bigger injectors like some 750 or something i wouldnt use those 450's for a 300 whp setup
Old Feb 23, 2006 | 03:10 PM
dohcdelsol's Avatar
Default Re: how do i get to the tune shop? (EGSR)
search
https://honda-tech.com/zerothread?id=1480469
my thread from a few weeks ago....
Old Feb 23, 2006 | 04:25 PM
White Smoke's Avatar
i my honda
Global Mod
You got the wrong manifold for a full rad. There is no real point to a full one anyway. A half sized will work just fine! Full size is only needed for road racing IMO.
But yes, that elbow will work. And yes a base map will work as well! Just dont boost AT ALL. Having a WB in the car helps!
Old Feb 23, 2006 | 04:50 PM
Soccerking3000's Avatar
Default Re: how do i get to the tune shop? (White Smoke)
just open the wastegate so you never build any boost...
Old Feb 23, 2006 | 05:13 PM
bigdaddyvtec's Avatar
* B A N N E D *
who built the manifold???
Old Feb 23, 2006 | 05:29 PM
HKSuperSi's Avatar
just tow your car.
Old Feb 23, 2006 | 07:09 PM
otto's Avatar
I was in the same boat. I decided it was safer to get it there by towing it. It's possibly cheaper to just drive it with the waste gate open though. Possibly because she could go boom before you even show up for your appointment. Do you take the chance?
Old Feb 23, 2006 | 07:12 PM
Default Re: how do i get to the tune shop? (otto)
you are fine ot run on a basemap seriously, dont go around flooring it and you'll be fine, if you dont have the self-control to not floor on the way to get it tuned you dont deserve the car.
Old Feb 23, 2006 | 07:46 PM
AbitAvenger's Avatar
Default Re: how do i get to the tune shop? (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">you are fine ot run on a basemap seriously, dont go around flooring it and you'll be fine, if you dont have the self-control to not floor on the way to get it tuned you dont deserve the car.</TD></TR></TABLE>word
Old Feb 23, 2006 | 07:52 PM
moesrex's Avatar
Default Re: how do i get to the tune shop? (AbitAvenger)
run stock ecu and stock injectors,itll be fine then!
Old Feb 23, 2006 | 08:20 PM
JDM00SI's Avatar
Default Re: how do i get to the tune shop? (moesrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moesrex &raquo;</TD></TR><TR><TD CLASS="quote">run stock ecu and stock injectors,itll be fine then! </TD></TR></TABLE>
Old Feb 24, 2006 | 05:40 AM
Schister66's Avatar
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigDaddyVTEC &raquo;</TD></TR><TR><TD CLASS="quote"> who built the manifold??</TD></TR></TABLE>
BUMP because i want to know....it looks like the ones from a shop in Fargo....SLS
Old Feb 24, 2006 | 06:15 AM
Default Re: (Schister66)
i'm actually not sure who built it...some local TI guy i met knew someone that made them. it's pretty good quality.
thanks for the response
Stylinhonda
Mar 27, 2006 01:53 PM
DreamCatcher
Jun 27, 2005 11:25 AM
hot93honda
Feb 18, 2005 01:28 PM
scratchy
Aug 20, 2004 05:41 AM
