how do i do a compression check for a 92 civic with a 94 ls engine
Old Jul 10, 2001 | 03:26 AM
Lei Siew Long's Avatar
Default how do i do a compression check for a 92 civic with a 94 ls engine
ok, i looked in c-speedracing's site and followed the instructions but am disappointed. first off, am i supposed to hear the engine crank or is it just quiet? secondly which fuses am i supposed to remove for the 92 civic? i went with the 15v fuse under the hood as stated in the site but i'm not sure if i'm removing the correct fuse.
i removed the 15v fuse, plugs and plug wires. tried to crank the engine but no sound and no compression readings.
ok here are the things that might effect this check: msd 6al, msd blaster 2 coil, and greddy turbo timer. would this things effect the test?
HELP. thanks in advance
Old Jul 10, 2001 | 05:40 AM
b18bturbo's Avatar
Default Re: how do i do a compression check for a 92 civic with a 94 ls engine (boostedeg6)
pull the coil wire off your distributor. Since you have Msd6al just take the coil wire off. Next thing you need to do is this. Take out plugs and plug wires. Start from the number 1 and move left Insert in compression tester crank about 5-6 times and you should get a reading.
Old Jul 10, 2001 | 08:23 AM
TurboInteg95's Avatar
you'll also want to remove the ECU fuse so the injectors wont spray.
ben42391
12
Dec 25, 2012 03:36 AM
motegicivic
Mar 8, 2012 05:13 AM
CivicSiDriver02
Feb 24, 2006 04:00 PM
DriveSlowHomie
Oct 25, 2005 07:28 PM
matto2413
Apr 10, 2005 05:10 PM
