Compression test
Old Feb 24, 2006 | 10:41 AM
CivicSiDriver02's Avatar
Default Compression test
I just have a couple questions on what fuses/connectors i need to pull for a compression test. Should I just pull the 15amp fuse under the hood for the fuel pump relay? What about the ingition coil?
Old Feb 24, 2006 | 10:56 AM
Sijray21's Avatar
Default Re: Compression test (CivicSiDriver02)
you should be fine just pulling the fuse for the fuel
Old Feb 24, 2006 | 11:02 AM
Default Re: Compression test (Sijray21)
Well that's what I thought but i had heard from some members as well as my auto teacher that you should also pull a fuse for the ignition so that you don't burn up the coil. Without anywhere for the electricity to ground out it will overheat your coil.
Old Feb 24, 2006 | 11:56 AM
Perfectionist's Avatar
I don't know about overheating, but the spark has to go somewhere. Without plugs to provide a ground path, the high voltage could break down through the coil to ground. Not a good situation.
Pull the fuse to be safe. Can't hurt.
Old Feb 24, 2006 | 12:00 PM
Default Re: Compression test (Perfectionist)
Which one should I pull? The 50 amp under hood fuse? Or will that not even allow me to crank the car? If not that one then which. Thanks for the help.
Old Feb 24, 2006 | 02:02 PM
Gqracer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSiDriver02 &raquo;</TD></TR><TR><TD CLASS="quote">Well that's what I thought but i had heard from some members as well as my auto teacher that you should also pull a fuse for the ignition so that you don't burn up the coil. Without anywhere for the electricity to ground out it will overheat your coil.</TD></TR></TABLE>
your teacher is correct.. you dont want to burn out the coil..
pull out the ecu main fuse
Old Feb 24, 2006 | 04:00 PM
Default Re: Compression test (Gqracer)
Thank you.
xJDMCx
May 29, 2009 06:10 PM
h22aBB4
Jun 5, 2007 05:52 PM
yh23
Aug 14, 2005 04:21 PM
jbiggsSE
Jul 16, 2004 06:41 AM
dutchman5
Mar 9, 2003 07:16 PM
